BQ34Z100学习完了以后,如果要量产的话,导出的gg.csv文件里面要改哪些参数才能烧录量产的产品?
  • golden 导出以后不需要修改参数。量产一般选择烧录SREC, BQFS, DFFS文件。更具您的需求选择
    3.6.1 Exporting the Flash Memory
    The .srec file contains the full flash memory. The .bq.fs contains the program memory portion for the flash
    memory and the .df.fs contains the data flash portion of the flash memory (see Figure 7).
    • Select the directory location to export the files.
    • Enter the file name for the files.
    • Select the files types to export.
    • Press the Create Image File button to export the memory and create the files.
