有关于ADS1298在文件sbaa188中的描述的患者地问题
2. Isolation Capacitance
Improving the isolation between the device ground and the patient ground helps to improve the system
CMR. For most portable instruments that use batteries, CMR is likely to be very high. Most typical test
methodologies to measure CMR, however, specify the minimum isolation capacitance C B at which the
system must pass the required CMR specification
 图框中的患者地该接在哪里?
