DS90UB935-Q1 in TIDA-01130
Other Parts Discussed in Thread: TIDA-01130, DS90UB953-Q1
HI
TIDA-01130 是否可以換935及936,達成OV2775開啟HDR模式
http://www.ti.com/lit/ug/tidud51a/tidud51a.pdf
  • OV2775 传输的是2MP MIPI 或者DVP 视频数据,但935只能支持到1MP/60fps 。
    所以不建议使用935, 还是建议按照tidud51a 推荐的953: The DS90UB953-Q1 serializer is part of TI's FPDLink III device family designed to support high-speed raw data sensors including 2MP imagers at 60-fps and as well as 4MP, 30-fps cameras, satellite RADAR, LIDAR, and Time-of-Flight (ToF) sensors.
    您这里为什么想要改成935?
