你好,
以下部分
Hi Michael,
This happened to me last week on a new Windows 10 machine. First I'd recommend that your customer installs Matlab Runtime version 8.5.1 32-bit (32-bit version is a MUST): www.mathworks.com/.../matlab-runtime.html
Next, make sure all four of the Com Ports for the Dev Pack are showing and correct as per the mmWave-DEVPACK User Guide (page 12): www.ti.com/.../swru506.pdf
Lastly, if you are having trouble installing the FTDI drivers in that section you will need to disable the digital signature security measure that is caused by Windows 10. I was able to find this through simple internet search but if you need help then let us know!
Cheers,
Akash
