编译工程
Other Parts Discussed in Thread: TMS320VC5505
编译一个工程出现了很多这样错误,不知道怎么解决。
  • 可否提供一下你的工程以及错误的截图呢?
    你这是什么芯片的什么程序?
  • AC0 |= 0x8000
    "..\i2s_register.asm", ERROR! at line 530: [E9999] Invalid mnemonic specified
    AC0 |= 0x8000
    "..\i2s_register.asm", ERROR! at line 531: [E9999] Illegal directive or
    mnemonic
    *port(#I2S1_CR_LSW)=AC0
    "..\i2s_register.asm", ERROR! at line 542: [E9999] Syntax Error
    AC0 = *port(#I2S2_CR_LSW)
    "..\i2s_register.asm", ERROR! at line 542: [E9999] Invalid mnemonic specified
    "..\i2s_register.asm", ERROR! at line 543: [E9999] Syntax Error
    AC0 |= 0x8000
    "..\i2s_register.asm", ERROR! at line 543: [E9999] Invalid mnemonic specified
    AC0 |= 0x8000
    "..\i2s_register.asm", ERROR! at line 544: [E9999] Illegal directive or
    mnemonic
    *port(#I2S2_CR_LSW)=AC0
    "..\i2s_register.asm", ERROR! at line 555: [E9999] Syntax Error
    AC0 = *port(#I2S3_CR_LSW)
    "..\i2s_register.asm", ERROR! at line 555: [E9999] Invalid mnemonic specified
    "..\i2s_register.asm", ERROR! at line 556: [E9999] Syntax Error
    AC0 |= 0x8000
    "..\i2s_register.asm", ERROR! at line 556: [E9999] Invalid mnemonic specified
    AC0 |= 0x8000
    "..\i2s_register.asm", ERROR! at line 557: [E9999] Illegal directive or
    mnemonic
    *port(#I2S3_CR_LSW)=AC0
    "..\i2s_register.asm", ERROR! at line 568: [E9999] Syntax Error
    AC0 = *port(#I2S0_CR_LSW)
    "..\i2s_register.asm", ERROR! at line 568: [E9999] Invalid mnemonic specified
    "..\i2s_register.asm", ERROR! at line 569: [E9999] Syntax Error
    AC0 &= 0x7FFF
    "..\i2s_register.asm", ERROR! at line 569: [E9999] Invalid mnemonic specified
    AC0 &= 0x7FFF
    "..\i2s_register.asm", ERROR! at line 570: [E9999] Illegal directive or
    mnemonic
    *port(#I2S0_CR_LSW)=AC0
    "..\i2s_register.asm", ERROR! at line 581: [E9999] Syntax Error
    AC0 = *port(#I2S1_CR_LSW)
    "..\i2s_register.asm", ERROR! at line 581: [E9999] Invalid mnemonic specified
    "..\i2s_register.asm", ERROR! at line 582: [E9999] Syntax Error
    AC0 &= 0x7FFF
    "..\i2s_register.asm", ERROR! at line 582: [E9999] Invalid mnemonic specified
    AC0 &= 0x7FFF
    "..\i2s_register.asm", ERROR! at line 583: [E9999] Illegal directive or
    mnemonic
    "..\i2s_register.asm", ERROR! at line 594: [E9999] Syntax Error
    "..\i2s_register.asm", ERROR! at line 594: [E9999] Invalid mnemonic specified
    "..\i2s_register.asm", ERROR! at line 595: [E9999] Syntax Error
    AC0 &= 0x7FFF
    "..\i2s_register.asm", ERROR! at line 595: [E9999] Invalid mnemonic specified
    AC0 &= 0x7FFF
    "..\i2s_register.asm", ERROR! at line 596: [E9999] Illegal directive or
    mnemonic
    "..\i2s_register.asm", ERROR! at line 607: [E9999] Syntax Error
    180 Assembly Errors, No Assembly Warnings
    "..\i2s_register.asm", ERROR! at line 607: [E9999] Invalid mnemonic specified
    "..\i2s_register.asm", ERROR! at line 608: [E9999] Syntax Error
    AC0 &= 0x7FFF
    这个是错误结果,用的是TMS320VC5505芯片,这个一个跟音频有关的程序
  • 你看下指向你程序的那些行的关联是怎样的,错误多没关系,往往一个点解决了就全解决了
  • 试试在ccs->Properties -> C/C++-Build -> Runtime Model Options下面勾选 "Codegen outputs algebraic assembly" ,"Select assembly source language" 选择 Algebraic。
