生成的out文件,无法下载dsp中
工程师你好,我用6678的评估版,自己编写的程序,编译通过,已经生成out文件了,链接不通过,
C66xx_0: Trouble Writing Memory Block at 0xa89800 on Page 0 of Length 0x2910: (Error -1190 @ 0xA23300) Unable to access device memory. Verify that the memory address is in valid memory. If error persists, confirm configuration, power-cycle board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.232.0)
C66xx_0: GEL: File: D:\workspace_v5_5\MyMessageQ\Debug\MyMessageQ.out: Load failed.
C66xx_0: Error: (Error -1190 @ 0x0) Unable to access device memory. Verify that the memory address is in valid memory. If error persists, confirm configuration, power-cycle board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.232.0)
