将40台机器断电,在零下-40C温度条件下静置2小时,而后开机,发现有4台机器无法正常上电启动,或者卡滞在开机界面,或者开机后短暂时间即发生重启黑屏现象,将主频设置在1.8GHZ,或者1.5GHZ可以解决,但是设置在1.2G或者1G无法解决,在1GHZ的情况下,将MPU的电压设置在0x67(1130mv)也可以解决,同时试过两片板子,都可以解决,目前还未找到root cause,希望TI帮忙查看
log如下
[18:53:34:922]dra7xx-evm login: (XEN) CPU1: Unexpected Trap: Data Abort
[18:53:34:923](XEN) ----[ Xen-4.6.1-pre arm32 debug=n Not tainted ]----
[18:53:34:923](XEN) CPU0: Unexpected Trap: Data Abort
[18:53:34:923](XEN) CPU: 1
[18:53:34:926](XEN) ----[ Xen-4.6.1-pre arm32 debug=n Not tainted ]----
[18:53:34:926](XEN) PC: 0021ee90CPU: 0
[18:53:34:927](XEN) csched_tick+0x50/0x304PC: 0021ee90
[18:53:34:927](XEN) csched_tick+0x50/0x304CPSR: 200e015a MODE:Hypervisor
[18:53:34:927](XEN)
[18:53:34:927](XEN) R0: 0027f164 R1: 3fd7bd00 R2: 4007c060 R3: 003003a0
[18:53:34:927](XEN) CPSR: 200c015a MODE:Hypervisor
[18:53:34:928](XEN) R4: 00300360 R5: 4000ac38 R6: 00000001 R7: 00300580
[18:53:34:928](XEN) R0: 0027f164 R1: 00000000 R2: 00300360 R3: 003003a0
[18:53:34:928](XEN) R8: 002fe020 R9: 00000001 R10:00000000 R11:00000000 R12:4007c080
[18:53:34:929](XEN) R4: 00300360 R5: 4000a248 R6: 00000000 R7: 00300580
[18:53:34:929](XEN) HYP: SP: 4001feac LR: 0022c00c
[18:53:34:931](XEN) R8: 002fe020 R9: 00000000 R10:00000000 R11:00000080 R12:00300380
[18:53:34:931](XEN)
[18:53:34:932](XEN) HYP: SP: 4006feac LR: 0022c00c
[18:53:34:932](XEN) VTCR_EL2: 80003558
[18:53:34:932](XEN)
[18:53:34:932](XEN) VTTBR_EL2: 000100027ff06000
[18:53:34:933](XEN) VTCR_EL2: 80003558
[18:53:34:933](XEN)
[18:53:34:933](XEN) VTTBR_EL2: 000100027ff06000
[18:53:34:933](XEN) SCTLR_EL2: 30cd187f
[18:53:34:934](XEN)
[18:53:34:934](XEN) HCR_EL2: 000000000038643f
[18:53:34:938](XEN) SCTLR_EL2: 30cd187f
[18:53:34:938](XEN) TTBR0_EL2: 00000000fa076000
[18:53:34:939](XEN) HCR_EL2: 000000000038643f
[18:53:34:940](XEN)
[18:53:34:940](XEN) TTBR0_EL2: 000000027fef9000
[18:53:34:940](XEN) ESR_EL2: 94000061
[18:53:34:941](XEN)
[18:53:34:941](XEN) HPFAR_EL2: 00000000027fe7f0
[18:53:34:941](XEN) ESR_EL2: 94000061
[18:53:34:941](XEN) HDFAR: 0027f16b
[18:53:34:941](XEN) HIFAR: 00000000
[18:53:34:943](XEN) HDFAR: 0027f16b
[18:53:34:944](XEN)
[18:53:34:944](XEN) HIFAR: 00000000
[18:53:34:944](XEN) Xen stack trace from sp=4001feac:
[18:53:34:944](XEN)
[18:53:34:945](XEN) 0000001eXen stack trace from sp=4006feac:
[18:53:34:945](XEN) 00000000 0000001e 94995000 00000000 0b2f1f23 37c0ee00 005dc000 0b2f2398 002c9df0 005dc000 0b2f1f23 002c9df0 00000000 0b2f2398
[18:53:34:945](XEN) 00000000 4007c100
[18:53:34:946](XEN) 0021ee40 00300400 00000001 0021ee40 0000001e 00000000 4000ac48 0000001e 002c9df0 4000a258 00000000 002c9df0 00000000 00000000
[18:53:34:946](XEN) 00000080 0022c00c
[18:53:34:946](XEN) 4007c100 0022c00c 40073098 00300400 8a3b16bf 4000ac98 0022c23c 8a474172 002c9df0 0022c23c 002c5e00 002c9df0 ffffffff 002c5e00
[18:53:34:951](XEN) ffffffff 00301614
[18:53:34:953](XEN) 002fe254 00301614 002c9df0 002fe254 00000000 002c9df0 00228828 00000000 00301614 00228828 002fe254 00301614 00301614 002fe254
[18:53:34:961](XEN) 00301614 002c5e00
[18:53:34:962](XEN) 003003dc 002c5e00 a0000000 003003dc 9fe00000 0027c280 002523a8 00000002 fa076000 002523a8 00000000 0027ee90 00000000 00000000
[18:53:34:962](XEN) 002c08b8 00000001
[18:53:34:962](XEN) 00000000 002fe264 a0000178 002fe254 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[18:53:34:963](XEN) 00000000 00000000
[18:53:34:963](XEN) 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[18:53:34:964](XEN) 00000000 00000000
[18:53:34:964](XEN) 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[18:53:34:970](XEN) 00000000 00000000
[18:53:34:972](XEN) 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[18:53:34:977](XEN) 00000000 00000000
[18:53:34:979](XEN) 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[18:53:34:983](XEN) 00000000 00000000
[18:53:34:983](XEN) 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[18:53:34:984](XEN) 00000000Xen call trace:
[18:53:34:984](XEN)
[18:53:34:984](XEN) [<0021ee90>] csched_tick+0x50/0x304 (PC)
[18:53:34:985](XEN) Xen call trace:
[18:53:34:985](XEN) [<0022c00c>] execute_timer+0x4c/0x6c (LR)
[18:53:34:985](XEN) [<0021ee90>] csched_tick+0x50/0x304 (PC)
[18:53:34:985](XEN)
[18:53:34:986](XEN)
[18:53:34:990](XEN) ****************************************
[18:53:34:991](XEN)
[18:53:34:991](XEN) Panic on CPU 1:
[18:53:34:991](XEN) CPU1: Unexpected Trap: Data Abort
[18:53:34:991](XEN)
[18:53:34:992](XEN) ****************************************
[18:53:34:992](XEN)
[18:53:34:992](XEN) Reboot in five seconds...
[18:53:34:992](XEN)
[18:53:34:992](XEN) Panic on CPU 0:
[18:53:35:006](XEN) CPU0: Unexpected Trap: Data Abort
[18:53:35:007](XEN)
[18:53:35:007](XEN) ****************************************
[18:53:35:008](XEN)
[18:53:35:008](XEN) Reboot in five seconds...
