内核修改如下:
1.menuconfig
1. 1Device Drivers --->
USB support --->
USB Serial Converter support --->
USB Generic Serial Driver
USB driver for GSM and CDMA modems
1.2 Device Drivers --->
Network device support --->
PPP (point-to-point protocol) support
PPP multilink support
PPP filtering
PPP support for async serial ports
PPP support for sync tty ports
1.3 Device Drivers --->
USB Network Adapters --->
Multi-purpose USB Networking Framework
2.4G设备添加
\drivers\usb\serial\option.c
static struct usb_device_id option_ids[] =
{ USB_DEVICE(0x19d2, 0x0117 },
{ USB_DEVICE(0x19d2, 0x0199) },
{ USB_DEVICE(0x19d2, 0x1476) }
添加单板类型匹配
printk("idVendor=%x, idProduct=%x, bInterfaceNumber =%d\r\n",
serial->dev->descriptor.idVendor,
serial->dev->descriptor.idProduct,
serial->interface->cur_altsetting->desc. bInterfaceNumber);
if (serial->dev->descriptor.idVendor == 0x19d2 &&
serial->dev->descriptor.idProduct == 0x1476 &&
serial->interface->cur_altsetting->desc. bInterfaceNumber == 3)
return -ENODEV;
serial->interface->cur_altsetting->desc. bInterfaceNumber == 4)
return -ENODEV;
serial->dev->descriptor.idProduct == 0x1509 &&
return -ENODEV;
serial->interface->cur_altsetting->desc. bInterfaceNumber == 5)
return -ENODEV;
