RM48L952添加F021_API_CortexR4_LE_V3D16_NDS.lib库函数,编译错误
近期调试flash API的库函数,已经将F021_API_CortexR4_LE_V3D16_NDS.lib添加到工程中,如下图所示:
                        编译工程时提示错误报警16004,具体如下:
                               #16004-D file "../lib/F021_API_CortexR4_LE_V3D16.lib<FlashStateMachine.FsmDoneEvent.obj>" has a Tag_PCS_config attribute value of "1" that is different than one previously seen ("0");
                        CCS5.5的配置如下:
                      有遇到此问题的小伙伴帮忙回复下,谢谢~
