TMS570的问题
Other Parts Discussed in Thread: TMS570LS1227
请问TMS570LS1227的CAN能否实现停止发送呢?我看其他芯片有类似的功能,可以强制停止当前正在重复发送的数据,并清除缓冲器里的数据。请问这个芯片有没有这个功能呢?多谢!
Does TMS570LS1227 CAN has the function which can stop frame sending in Can Core?  I found other Microcontrollers have this sort of function, can be forced to stop the data that is currently being repeated to send and clear the data in the buffer。Does this product have this function?Thank you very much!
