TMS570中flexray的single-solt模式跟continue-solt模式有什么区别
我的理解就是单次传输和连续传输的区别。
Each transmit buffer provides a transmission mode flag TXM that allows the host to configure the transmission mode for the transmit buffer. If this bit is set, the transmitter operates in the single-shot mode. If this bit is cleared, the transmitter operates in the continuous mode.
是由TXM这个标志决定的。
具体可以看手册的1084页。
