官网下的Z-Stack-Mesh-1.0.0.exe,安装完后没做任何改动,在f8wRouter.cfg中加入以下代码
/* 错误路由次数 */ -DLINK_DOWN_TRIGGER=12 /* Link Status 丢失上限 */ -DNWK_ROUTE_AGE_LIMIT=30 /* 广播存活时间 */ -DBCAST_DELIVERY_TIME=100 /* 消息传递级数 */ -DDEF_NWK_RADIUS=15 /* Route Request 的广播半径 */ -DDEFAULT_ROUTE_REQUEST_RADIUS=8 /* Route Discovery 持续时间 */ -DROUTE_DISCOVERY_TIME=13 /* 关闭跳频 */ -DZDNWKMGR_MIN_TRANSMISSIONS=0 /* Link Status 发送间隔 */ -DNWK_LINK_STATUS_PERIOD=30 -DMAX_NEIGHBOR_ENTRIES=48
编译后出现
Error[e104]: Failed to fit all segments into specified ranges. Problem discovered in segment XDATA_N. Unable to place 2 block(s) (0xc02 byte(s) total) in 0xa0f byte(s) of memory. The problem occurred while processing the segment
placement command "-P(XDATA)XDATA_N=_XDATA_START-_XDATA_END", where at the moment of placement the available memory ranges were "XDATA:14f1-1eff"
也就是内存不足,请问哪里出错了,我是按照 AN123 文档的 Ch.4 来配置的。
