mmwave_studio_02_00_00_02软件启动报错问题
当启动 "C:\ti\mmwave_studio_02_00_00_02\mmWaveStudio\RunTime\mmWaveStudio.exe"时,在Output 界面提示如下错误信息,该如何解决?
GM: Constructor
GM: Wed Aug 07 17:03:24 2019
RSTD.Transmit("/Settings")
[17:03:24]
[17:03:24] ### Running Startup script: "C:\ti\mmwave_studio_02_00_00_02\mmWaveStudio\Scripts\Startup.lua" ###
[17:03:24] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[17:03:24] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[17:03:24] Scripter ignored: Attempt to UnBuild() again or before Build.
[17:03:24] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\Clients\\\\LabClient.dll")
[17:03:24] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[17:03:24] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[17:03:24] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[17:03:24] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[17:03:24] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[17:03:24] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\RunTime\\SAL.dll")
[17:03:24] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[17:03:24] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[17:03:24] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[17:03:24] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[17:03:24] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[17:03:24] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[17:03:24] RSTD.Transmit("/")
[17:03:24] RSTD.SaveSettings(): Settings saved to "C:\Users\Administrator\AppData\Roaming\RSTD\config.xml"
[17:03:24] RSTD.Build()
[17:03:24] RSTD.AL_Build()
[17:03:24] RSTD.AL_LoadXml()
[17:03:24] RSTD.AL_Init()
[17:03:24] RSTD.Clients_Build()
[17:03:24] GM: Init
[17:03:24] GM: Loaded 'C:\ti\mmwave_studio_02_00_00_02\mmWaveStudio\Clients\\LabClient.dll'
[17:03:24] GM: 1 Guest (s) init
[17:03:24] GM: 1 Module(s) init
[17:03:24] GM: 2 Tab (s) init
[17:03:24] RSTD.Client_LoadXml()
[17:03:25] [RadarAPI]: Starting Matlab Engine..
[17:03:25] [RadarAPI]: Error: “MatlabPostProcGui.MatlabPostProcGUIClass”的类型初始值设定项引发异常。
[17:03:25] Trace:
[17:03:25] 在 MatlabPostProcGui.MatlabPostProcGUIClass..ctor()
[17:03:25] 在 AR1xController.frmAR1Main.InitMatlabPostProcEngine(String PostProcesspath)
[17:03:25] [RadarAPI]: Error: Error occured in Matlab Initialization
[17:03:25] [RadarAPI]: Matlab Engine couldn't be Started..
[17:03:27] [RadarAPI]: ar1.LoadSettings('C:\Users\Administrator\AppData\Roaming\RSTD\ar1gui.ini')
[17:03:27] [RadarAPI]: Error: 未将对象引用设置到对象的实例。
[17:03:27] Trace:
[17:03:27] 在 AR1xController.ScriptOps.getMatlabPostProcVersion()
[17:03:27] TESTING = false
[17:03:27]
[17:03:27] ***Script completed successfully.***
