求助:关于MSP430G255310位ADC的采样问题
那天写了一个ADC转换的问题,通过A0通道采样。把P1.0设置为输入,但ADC10CTL0 |= ADC10SC;这条语句一执行。P1.0就有电压了,本来应该是0伏特。如果把那条语句屏蔽了,P1.0就是0V。给P1.0配置下拉电阻,不采集的时候是0,但采集时误差太大了。各位大神能帮我看下问题出在哪儿了吗?谢谢!程序代码如下:
#include <msp430g2553.h>
#define uint unsigned int
 #define uchar unsigned char
 #define Num_of_Results 32
 static uint results[Num_of_Results]; /*宏定义各端口,RS(CS)串行通信片选,SID(R/W)串行数据口,SCLK(E)串行同步时钟信号*/
#define RS_0 P2OUT &= ~BIT0     //RS = 0
#define RS_1 P2OUT |= BIT0      //RS = 1
#define SID_0 P2OUT &= ~BIT1    //SID = 0
#define SID_1 P2OUT |= BIT1     //SID = 1
#define SCLK_0 P2OUT &= ~BIT2   //SCLK = 0
#define SCLK_1 P2OUT |= BIT2    //SCLK = 1
uchar m;
unsigned long temp, IntDegF, IntDeg;
void ADC10_init()
   ADC10CTL0 &= ~ENC;
   ADC10CTL0 = ADC10IE+ADC10ON+ADC10SHT_2+MSC+SREF_2;   //ADC10ON开启10ADC
   ADC10CTL1 = CONSEQ_2+INCH_0
;   ADC10AE0 |= 0X03;
   ADC10SA = 0X200;
   __delay_cycles(30000);
   ADC10CTL0 |= ENC;
   ADC10CTL0 &= ~ADC10IFG;
   _EINT();
   //LPM0;
delay_1ms(): 延时函数
 输入参数:无
 编写日期:20140722
void delay_1ms()
   uint k;
   for(k=0; k<195; k++);
delay(uint n): 延时函数,延时大约1ms
 输入参数:n 延时nms
编写日期:20140722
 void delay1ms(uint n)
 {   uint j;   for(j=0; j<n; j++)     delay_1ms(); }
/*写指令函数*/
 void write_cmd(uchar cmd)
   uchar j;
   j = 0xF8;
   RS_1;             //RS=1
   SCLK_0;            //SCLK=0(E)
   for(m=0; m<8; m++)
     if(j&0x80)          //判断最高位是否是为1,如果是则给SDIN赋1即写入1,否则写0
       SID_1;       //SID(RW)
     else        SID_0;    //最高位不为1,写0
     SCLK_0;      //让SCLK产生下降沿,使液晶采样
     delay1ms(1);
     SCLK_1;       //将SCLK拉高,为一位数据采样做准备
     j=j<<1;            //因为先发送高位,所以每次向左移动一位
   j = cmd;
   j &= 0xF0;
   for(m=0; m<8; m++)
       SID_1;
     else
        SID_0;    //最高位不为1,写0
     delay1ms(1);
   j = cmd;
   j <<= 4;
   for(m=0; m<8; m++)
       SID_1;
     else
        SID_0;    //最高位不为1,写0
     delay1ms(1);
   RS_0;
   delay1ms(5);
/*写显示数据函数*/
 void write_data(uchar dat)
   uchar j;
   j = 0xFA;
   RS_1;
   for(m=0; m<8; m++)
       SID_1;
     else
        SID_0;    //最高位不为1,写0
     delay1ms(1);
   j = dat;
   j &= 0xF0;
   for(m=0; m<8; m++)
       SID_1;
     else
        SID_0;    //最高位不为1,写0
     delay1ms(1);
   j = dat;
   j <<= 4;
   for(m=0; m<8; m++)
       SID_1;
     else
        SID_0;    //最高位不为1,写0
     delay1ms(1);
   RS_0;
   delay1ms(5); }
/*设定显示位置*/
 void lcd_pos(uchar X, uchar Y)
   uchar pos;
   if(X == 0)
     X = 0x80;
   else if(X == 1)
     X = 0X90;
   else if(X == 2)
     X = 0X88;
   else if(X == 3)
     X = 0X98;
   pos = X+Y;
   write_cmd(pos);      //显示地址
/*LCD初始化设定*/
 void lcd_init()
   //P1OUT &= ~BIT3;
   //PSB = 1;并口方式
   write_cmd(0x30); //基本指令操作
   delay1ms(5);
   write_cmd(0x0c); //显示开,关光标
   delay1ms(5);
   write_cmd(0x01); //清除LCD的显示类容
   delay1ms(5); }
 Init_Port(): MSP430G2553端口初始化函数
 输入参数:无
 编写日期:20140722
 void Init_Port()
    P1DIR = 0;          //将P1口所有的管脚在初始化的时候设置为输入方式
   P2DIR = 0;          //将P2口所有的管脚在初始化的时候设置为输入方式
   //P1REN |= BIT0;
   //P1OUT &= ~BIT0
;   P1SEL |= BIT0;          //将P1口所有的管脚设置为一般I/O口
   P1DIR &= ~BIT0;
   P1DIR |= BIT4;
   P2SEL = 0X00;
   P2IE = 0X00;
   P2DIR = 0XFF;       //将P2口所有的管脚在初始化的时候设置为输入方式
void display(long date)
   uchar ge, shi, bai, qian;
   qian=date/1000;
   bai=date%1000/100;
   shi=date%1000%100/10;
   ge=date%1000%100%10;
   lcd_pos(0,2);
   write_data(0x30+qian);
   write_data(0x30+bai);
   lcd_pos(0,3);
   write_data(0x30+shi);
   write_data(0x30+ge);
void main()
   WDTCTL = WDTPW + WDTHOLD;
   BCSCTL1 = CALBC1_8MHZ;
   DCOCTL = CALDCO_8MHZ;
   Init_Port();
   lcd_init();
   ADC10_init();
   while(1);
#pragma vector = ADC10_VECTOR
 __interrupt void ADC10ISR()
   uchar i;
   P1DIR |= BIT4;
   P2DIR |= BIT0+BIT1+BIT2;
   static uint index = 0;
   results[index++] = ADC10MEM;
   if(index >= Num_of_Results)
     unsigned long sum = 0;
    index = 0;
    for(i = 0; i < Num_of_Results; i++)
         sum += results[i];
     sum >>= 5;                            //除以32
     temp = 3300*sum/1023;
     display(temp);
