0 = Average discharge current from previous cycle: There is an internal register that records the
average discharge current through each entire discharge cycle. The previous average is stored in
this register.
1 = Present average discharge current: This is the average discharge current from the beginning of
this discharge cycle till present time.
2 = Current: based off of Current
3 = Average Current (default): based off the Average Current
4 = Design Capacity / 5: C Rate based off of Design Capacity /5 or a C / 5 rate in mA.
5 = AtRate (mA): Use whatever current is in AtRate
6 = User_Rate-mA: Use the value in User_Rate-mA. This gives a completely user configurable
method.
7 = Maximum of Average Current from the previous discharge cycle.
