【电源分享】常见问题解答(持续更新中, 更新至3/29/2021)
2021
[常见问题解答] CCS/LP5036:如何在五分钟内掌握 LP50xx 器件?请提供 LP5009、LP5012、LP5018、LP5024、LP5030、LP5036 器件的快速入门指南
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/201386
[常见问题解答] 使用 TPS929120-Q1 在 5 分钟内设计汽车动画照明
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/201388
[常见问题解答] TPS546D24A:USB 转 GPIO 转换器是否具有内部上拉功能?多大电阻?多大电压?
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/201387
大功率PFC的选型
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/200140
大功率隔离电源转换的选型
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/200141
电压电流模式的差异
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/200143
反激芯片的选择
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/200145
恒压恒流控制芯片选择
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/200147
2020
Powerpad功能:
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/189722
Split-Rail Power:
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/189723
负压电源设计:
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/189724
输入过压 & 静态电流:
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/190072
并联电源:
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/192632
降低芯片功耗:
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/192633
输出可调:
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/192634
100% duty 设计:
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/196260
LDO与LC滤波:
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/196261
TPS63XXX系列LED设计:
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/196262
TEC电路设计:
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/196263
额外的软起动设计:
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/196268
低功耗AC / DC电源的实用EMI注意事项:
https://e2echina.ti.com/question_answer/analog/power_management/f/24/t/196625
【电池分享】常见问题解答(持续更新中, 更新至3/29/2021)
[常见问题解答] 无线电源 RX 的启动疑难解答
https://e2echina.ti.com/question_answer/analog/battery_management/f/35/t/201382
[常见问题解答] BQ24040 和 BQ2404X 系列 NTC 和 TTDM 模式 TS 引脚配置
https://e2echina.ti.com/question_answer/analog/battery_management/f/35/t/201379
[常见问题解答] BQ77216:如何减少电池节数?
https://e2echina.ti.com/question_answer/analog/battery_management/f/35/t/201381
BQ40Z80 常见问题
https://e2echina.ti.com/question_answer/analog/battery_management/f/35/t/200172
BQ24133, BQ24170, BQ24171 & BQ24172:原理图审查和PCB布局设计技巧
https://e2echina.ti.com/question_answer/analog/battery_management/f/35/t/200173
bq27441的Taper Rate参数应该是多少
https://e2echina.ti.com/question_answer/analog/battery_management/f/35/t/200176
关于CEDV跟Impedance track 这两种算法的区别和应用范围
https://e2echina.ti.com/question_answer/analog/battery_management/f/35/t/200177
BQ25710,BQ25713,BQ25713B,BQ25700A,BQ25703A,BQ25708-原理图审查设计建议:
https://e2echina.ti.com/question_answer/analog/battery_management/f/35/t/189719
BQ76930或bq76940:启动后报告零伏:
https://e2echina.ti.com/question_answer/analog/battery_management/f/35/t/189720
GPC工具套件:
https://e2echina.ti.com/question_answer/analog/battery_management/f/35/t/189721
BQ24133设定充电电流的精度偏差是多少:
https://e2echina.ti.com/question_answer/analog/battery_management/f/35/t/192628
TI单节电量计基本介绍及常见问题解答:
https://e2echina.ti.com/question_answer/analog/battery_management/f/35/p/46539/286088
关于BQ34Z100-G1学习的常见疑问:
https://e2echina.ti.com/question_answer/analog/battery_management/f/35/t/192629
BQ28Z610 过温保护失效且过流、短路保护不能自动自动恢复问题:
https://e2echina.ti.com/question_answer/analog/battery_management/f/35/t/196269
BQ40Z80 MAX ERROR 从1%变成101%问题:
https://e2echina.ti.com/question_answer/analog/battery_management/f/35/t/196273
Bq40z80充电过程中无SMBUS通信,延时几秒后充电MOS关闭:
BQ76PL455A-Q1与MCU隔离后无法唤醒问题和自动寻址问题:
https://e2echina.ti.com/question_answer/analog/battery_management/f/35/t/196271
BQ24133输入端MOS管作用以及D1 D2的作用:
https://e2echina.ti.com/question_answer/analog/battery_management/f/35/t/196272
