真心求救一下工程师们,ADS1675高速模式采样程序,感觉自己写的没有问题,现在问题主要是倍频不上去,求工程师们帮忙看一下程序!
Other Parts Discussed in Thread: ADS1675
-- Company:
-- Engineer:
-- Create Date: 08:53:13 06/10/2019
-- Design Name:
-- Module Name: ADC1675_1 - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity ADC1675_1 is
Port (
AD_CLK : in STD_LOGIC; --ADC时钟输入
CS : out STD_LOGIC;
START_1 : out STD_LOGIC;
DRATE_0 : out STD_LOGIC;
DRATE_1 : out STD_LOGIC;
DRATE_2 : out STD_LOGIC;
FPATH : out STD_LOGIC;
LL_CONFIG : out STD_LOGIC;
LVDS : out STD_LOGIC;
SCLK_SEL : out STD_LOGIC;
PDWN : out STD_LOGIC;
ADOUT : out STD_LOGIC_VECTOR(23 downto 0);
ADC_DRDY : in STD_LOGIC;
-- DRDY : in STD_LOGIC; -- /DRDY_1
AD_DOUT : in STD_LOGIC;
-- DOUT : in STD_LOGIC; --/DOUT_1
AD_SCLK : in STD_LOGIC
-- SCLK_N : in STD_LOGIC --/SCLK_1
end ADC1675_1;
architecture Behavioral of ADC1675_1 is
type states is (init,start,decide_2,data,work);
signal state : states := init;
type states1 is (clk_int,delay,clk_wait,clk_star);
signal state1 : states1 := clk_int;
signal START_11 : std_logic;
signal datreg_value : std_logic_vector (23 downto 0); --24位数据
signal acqdat_count : std_logic_vector(4 downto 0);--采集数据计数
signal counter : std_logic_vector(10 downto 0); --PLL延时计数
signal one : std_logic; signal two : std_logic; signal three : std_logic; signal four : std_logic; signal five : std_logic; signal six : std_logic;
signal seven : std_logic; signal eight : std_logic; signal nine : std_logic; signal ten : std_logic; signal eleven : std_logic; signal twelve : std_logic;
signal thirteen : std_logic; signal fourteen : std_logic; signal fifteen : std_logic; signal sixteen : std_logic; signal seventeen : std_logic; signal eighteen : std_logic;
signal nineteen : std_logic; signal twenty : std_logic; signal twenty_one : std_logic; signal twenty_two : std_logic; signal twenty_three : std_logic; signal twenty_four : std_logic;
begin
process (AD_CLK)
begin
IF (AD_CLK'event and AD_CLK = '1') then --启动配置
case state1 is
when clk_int =>
PDWN <= '1';--上电
CS <= '0';--芯片未选择 单通道
DRATE_0 <= '1'; -- 控
DRATE_1 <= '0'; -- 制
DRATE_2 <= '1'; -- 速度
FPATH <= '0'; --
LL_CONFIG <= '1';
LVDS <= '0';
SCLK_SEL <= '0';
START_11 <= '0';
state1 <= delay;
when delay =>
if(counter = "11111100000") then
counter <= "00000000000";
state1 <= clk_wait;
else
counter <= counter +1;
state1 <= delay;
end if;
when clk_wait =>
if(ADC_DRDY='1') then
START_11 <= '1';
state1 <= clk_star;
else
START_11 <= '0';
state1 <= clk_wait;
end if;
when clk_star =>
START_11 <= '1';
state1 <= clk_star;
end case;
end IF;
end process;
process (AD_SCLK)
begin
IF (AD_SCLK'event and AD_SCLK = '1') then
case state is
when init =>
acqdat_count <= "00000";
datreg_value <= X"000000";
state <= start;
when start =>
if (START_11 = '1') then
START_1 <= '1';
state <= decide_2;
else
START_1 <= '0';
state <= start;
end if;
when decide_2 =>
if(ADC_DRDY = '1') then
twenty_four <= AD_DOUT;
acqdat_count <= "00001";
state <= work;
else
state <=decide_2;
end if;
when work =>
case acqdat_count is
-- when "00000"=>
-- twenty_four <= AD_DOUT; acqdat_count <= "00001"; state <= decide_2; --1
when "00001"=>
twenty_three <= AD_DOUT; acqdat_count <= "00010"; state <= work;
when "00010"=>
twenty_two <= AD_DOUT; acqdat_count <= "00011"; state <= work;
when "00011"=>
twenty_one <= AD_DOUT; acqdat_count <= "00100"; state <= work;
when "00100"=>
twenty <= AD_DOUT; acqdat_count <= "00101"; state <= work;
when "00101"=>
nineteen <= AD_DOUT; acqdat_count <= "00110"; state <= work;
when "00110"=>
eighteen <= AD_DOUT; acqdat_count <= "00111"; state <= work;
when "00111"=>
seventeen <= AD_DOUT; acqdat_count <= "01000"; state <= work;
when "01000"=>
sixteen <= AD_DOUT; acqdat_count <= "01001"; state <= work;
when "01001"=>
fifteen <= AD_DOUT; acqdat_count <= "01010"; state <= work; --10
when "01010"=>
fourteen <= AD_DOUT; acqdat_count <= "01011"; state <= work;
when "01011"=>
thirteen <= AD_DOUT; acqdat_count <= "01100"; state <= work;
when "01100"=>
twelve <= AD_DOUT; acqdat_count <= "01101"; state <= work;
when "01101"=>
eleven <= AD_DOUT; acqdat_count <= "01110"; state <= work;
when "01110"=>
ten <= AD_DOUT; acqdat_count <= "01111"; state <= work; --15
when "01111"=>
nine <= AD_DOUT; acqdat_count <= "10000"; state <= work;
when "10000"=>
eight <= AD_DOUT; acqdat_count <= "10001"; state <= work;
when "10001"=>
seven <= AD_DOUT; acqdat_count <= "10010"; state <= work;
when "10010"=>
six <= AD_DOUT; acqdat_count <= "10011"; state <= work; --19
when "10011"=>
five <= AD_DOUT; acqdat_count <= "10100"; state <= work;
when "10100"=>
four <= AD_DOUT; acqdat_count <= "10101"; state <= work;
when "10101"=>
three <= AD_DOUT; acqdat_count <= "10110"; state <= work;
when "10110"=>
two <= AD_DOUT; acqdat_count <= "10111"; state <= work;
when "10111"=>
one <= AD_DOUT; acqdat_count <= "00000"; state <=data;
when others => null;
end case;
when data =>
ADOUT <= twenty_four&twenty_three&twenty_two&twenty_one&twenty&nineteen&eighteen&seventeen&sixteen&fifteen&fourteen&thirteen&twelve&eleven&ten& nine&eight&seven&six&five&four&three&two&one;
state <= decide_2;
end case;
end IF;
end process;
end Behavioral;
  • 顶层的程序
    -- Company:
    -- Engineer:
    -- Create Date: 08:51:23 06/10/2019
    -- Design Name:
    -- Module Name: TOP - Behavioral
    -- Project Name:
    -- Target Devices:
    -- Tool versions:
    -- Description:
    -- Dependencies:
    -- Revision:
    library IEEE;
    use ieee.std_logic_misc.all;
    library UNISIM;
    use UNISIM.VCOMPONENTS.ALL;
    --library UNISIM;
    entity TOP is
    port(
    CS_1 : inout STD_LOGIC;
    START : inout STD_LOGIC;
    DRATE_0_1 : inout STD_LOGIC;
    DRATE_1_1 : inout STD_LOGIC;
    DRATE_2_1 : inout STD_LOGIC;
    FPATH_1 : inout STD_LOGIC;
    LL_CONFIG_1 : inout STD_LOGIC;
    LVDS_1 : inout STD_LOGIC;
    SCLK_SEL_1 : inout STD_LOGIC;
    PDWN_1 : inout STD_LOGIC;
    CLK_IN : in STD_LOGIC;
    AD_CLK_1 : inout STD_LOGIC;
    AC_DRDY_1 : in STD_LOGIC;
    DRDY_1 : in STD_LOGIC; -- /DRDY_1 差分信号--DRDY
    AD_DOUT_1 : in STD_LOGIC;
    DOUT_1 : in STD_LOGIC; --/DOUT_1
    AD_SCLK_1 : in STD_LOGIC;
    SCLK_1 : in STD_LOGIC --/SCLK_1
    end TOP;
    architecture Behavioral of TOP is
    COMPONENT fenpin
    PORT(
    clk_in : IN std_logic;
    clk_out_8mhz_1 : out STD_LOGIC;
    clk_out_8mhz : OUT std_logic
    END COMPONENT;
    COMPONENT ADC1675_1
    Port ( AD_CLK : in STD_LOGIC;
    CS : out STD_LOGIC;
    ADOUT : out std_logic_vector(23 downto 0);
    -- A : out STD_LOGIC_VECTOR(7 downto 0);
    -- B : out STD_LOGIC_VECTOR(7 downto 0);
    -- C : out STD_LOGIC_VECTOR(7 downto 0);
    -- D : out STD_LOGIC_VECTOR(7 downto 0);
    END COMPONENT;
    COMPONENT ICON
    PORT (
    CONTROL0 : INOUT STD_LOGIC_VECTOR(35 DOWNTO 0)
    END COMPONENT;
    COMPONENT ILA
    PORT (
    CONTROL : INOUT STD_LOGIC_VECTOR(35 DOWNTO 0);
    CLK : IN STD_LOGIC;
    TRIG0 : IN STD_LOGIC_VECTOR(31 DOWNTO 0)
    END COMPONENT;
    --component PLL
    --port
    -- CLK_IN1 : in std_logic;
    -- CLK_OUT1 : out std_logic;
    -- RESET : in std_logic;
    -- LOCKED : out std_logic
    --end component;
    SIGNAL CLK_8MHZ_TMP : std_logic;
    SIGNAL icont: std_logic_vector(35 downto 0);
    SIGNAL AD_OUT1_TMP : std_logic_vector(23 downto 0);
    SIGNAL AD_SCLK_TMP : std_logic;
    SIGNAL AD_CLK_TMP : std_logic;
    SIGNAL AC_DRDY_TMP : std_logic;
    SIGNAL AD_DOUT_TMP : std_logic;
    -- SIGNAL AA : std_logic_vector(7 downto 0);
    -- SIGNAL BB : std_logic_vector(7 downto 0);
    -- SIGNAL CC : std_logic_vector(7 downto 0);
    -- SIGNAL DD : std_logic_vector(7 downto 0);
    begin
    IBUFDS
    PORT MAP(
    DIFF_TERM=>FALSE,
    IOSTANDARD => LVDS_33
    SCLK: IBUFGDS
    PORT MAP
    I => AD_SCLK_1,
    IB=>SCLK_1,
    O=>AD_SCLK_TMP
    DRDY :IBUFDS
    PORT MAP
    I => AC_DRDY_1,
    IB=>DRDY_1,
    O=>AC_DRDY_TMP
    DOUT: IBUFDS
    PORT MAP
    I => AD_DOUT_1,
    IB=>DOUT_1,
    O=>AD_DOUT_TMP
    Inst_fenpin: fenpin PORT MAP(
    clk_in => CLK_IN,
    clk_out_8mhz_1=> AD_CLK_1 ,
    clk_out_8mhz => CLK_8MHZ_TMP
    Inst_ADC1675 : ADC1675_1 PORT MAP(
    AD_CLK => CLK_8MHZ_TMP,
    CS => CS_1,
    START_1 => START,
    DRATE_0 => DRATE_0_1,
    DRATE_1 => DRATE_1_1,
    DRATE_2 => DRATE_2_1,
    FPATH => FPATH_1,
    LL_CONFIG => LL_CONFIG_1,
    LVDS => LVDS_1,
    SCLK_SEL => SCLK_SEL_1,
    PDWN => PDWN_1,
    ADOUT => AD_OUT1_TMP,
    -- A => AA,
    -- B => BB,
    -- C => CC,
    -- D => DD,
    ADC_DRDY => AC_DRDY_TMP,
    -- DRDY => DRDY_1,
    AD_DOUT => AD_DOUT_TMP,
    -- DOUT => DOUT_1,
    AD_SCLK => AD_SCLK_TMP
    -- SCLK_N => SCLK_1
    --CHIPSCOPE3 : PLL
    -- port map
    -- CLK_IN1 => CLK_8MHZ_TMP,
    -- CLK_OUT1 => AD_SCLK_TMP,
    -- RESET => RESET,
    -- LOCKED => LOCKED
    CHIPSCOPE1 : ICON
    port map (
    CONTROL0 => icont
    CHIPSCOPE2 : ILA
    port map (
    CONTROL => icont,
    CLK =>CLK_IN,
    --TRIG0 =>X"000000"&DRATE_0_1&DRATE_1_1&DRATE_2_1&AD_SCLK_TMP&AD_DOUT_TMP&AC_DRDY_TMP&CLK_16MHZ_TMP&START
    -- TRIG0 =>DD&CC&BB&AA
    TRIG0 => "000"&AD_OUT1_TMP&AD_DOUT_TMP&AD_SCLK_TMP&AC_DRDY_TMP&CLK_8MHZ_TMP&START
    end Behavioral;
  • 什么环境的程序?  你这是 linux 程序吗,   希望  TI 官方的人员能够支持
