bq25892 i2c 通讯不能收到应答信号
void Drv_I2C_Config( void )
        GPIO_InitTypeDef GPIO_InitStruct;
/* GPIO Ports Clock Enable */
I2C1_SCL_GPIO_CLK_ENABLE();
        I2C1_SDA_GPIO_CLK_ENABLE();
/*Configure GPIO pin : BAT_INT_Pin */
GPIO_InitStruct.Pin = BAT_I2C1_SCL_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
HAL_GPIO_Init(BAT_I2C1_SCL_GPIO_Port, &GPIO_InitStruct);
GPIO_InitStruct.Pin = BAT_I2C1_SDA_Pin;
HAL_GPIO_Init(BAT_I2C1_SDA_GPIO_Port, &GPIO_InitStruct);
        I2C_SCL_H;
        I2C_SDA_H;
void Drv_I2C_Start( void )
        I2C_SCL_H;
        I2C_SDA_H;
        i2c_Delay();
        I2C_SDA_L;
        i2c_Delay();
        I2C_SCL_L;
        i2c_Delay();
Params: void
Return: void
Description: CPU·¢ÆðI2C×ÜÏßÍ£Ö¹ÐźÅ
void Drv_I2C_Stop( void )
        I2C_SDA_L;
        I2C_SCL_H;
        i2c_Delay();
        I2C_SDA_H;
void Drv_I2C_SendByte( uint8_t dat )
        uint8_t i;
        for (i = 0; i < 8; i++)
               I2C_SCL_L;
               i2c_Delay();
               if(dat & 0x80)
                       I2C_SDA_H;
               else
                       I2C_SDA_L;
               dat <<= 1;
               i2c_Delay();
               I2C_SCL_H;
               i2c_Delay();
        I2C_SCL_L;
        i2c_Delay();
uint8_t Drv_I2C_WaitAck(void)
        uint8_t re;
        SDA_Input();
        I2C_SCL_L;
        i2c_Delay();
        I2C_SDA_H;
        i2c_Delay();
        I2C_SCL_H;
        i2c_Delay();
        if(I2C_SDA_GET)
               re = 1;
        else
               re = 0;
        I2C_SCL_L;
        i2c_Delay();
        SDA_Output();
        return re;
我使用的是stm32l8的芯片,i2c周期大概是10us,写地址0x6B,无应答信号,我使用这个程序写eeprom的地址0xA0,是有应答。
原理图如下,VCC_USB使用5V电压输入,VBAT和VBAT_SYS_OUT都有有4.2V电压。
