由于国庆节假期,帖子审批以及工程师回复将会有所延迟,敬请谅解。
Question about LMR14030 thermal resistance : RθJC
Hi
I just found some questions about thermal resistance RθJC  in LMR14030
According to JEDEC's specification of thermal resistance, RθJA=RθJC+RθCA.
So in this case RθJA should be greater than RθJC
However, in the specification of LMR14030, it is obvious that RθJC is larger than RθJA, which is not in accordance with the thermal resistance standard defined by JEDEC.
Can you help confirm why the RθJC is larger than RθJA in LMR14030?
Thanks
Jason
