运行5505的固化程序,是官方的例程programmer工程,头两次烧写都是正确的,校验没有出错,但是在第三次试的时候出现问题,写进去的和读进去的不一致。不知道是什么问题。而且,有一个现象是,之前在点击运行程序后,直接弹出提示,即选择哪种固化方式,但是在后几次运行过程中,点击运行后,console区域会显示上图的语句
C55xx: Trouble Reading Memory Block at 0x1b00 on Page 2 of Length 0x1: (Error -1143 @ 0x1B00) Device core was hung. The debugger has forced the device to a ready state and recovered debug control, but your application's state is now corrupt. You should have limited access to memory and registers, but you may need to reset the device to debug further. (Emulation package 5.1.641.0)
不知道是什么原因,希望大神指点一下,谢谢。
