代码在VC上编译通过且能正确运行,但是移植到C55xx Rev3.0 CPU Functional Simulator上运行报错
#10202-D no suitable entry-point found; setting to 0
然后编译的时候报错 单步调试的时候出现错误
TMS320C55x: Can't Single Step Target Program: Check the linker command file / map file for any part of the program going into reserved area and correct the problem when Program Counter is 0x0 NOTE: Reset the target, reload the corrected program and continue execution
TMS320C55x: Can't Single Step Target Program: Unknown Fatal Error
