关于CCS3.3安装的问题
我的系统是XP32位(虚拟机),从官网下载了CCS3.3,每次安装都是:安装到最后,安装进度条满了,就立刻死机。
虚拟机环境是VM14和VM15,XP的SP1和SP3都尝试过,现象完全一样(4个组合都试过,完全一样,折腾了好久了,求助)
天高云阔,风语如歌。
  • 看一下ccsv3对系统的要求。另外建议用新版的ccs,ccsv3很老了。
    processors.wiki.ti.com/.../System_Requirements
    若该回复解决了您的问题,请点击“确认此为答案”,谢谢。
  • 回复 Nancy Wang:
    系统 是满足要求的,内存2g,预留了32g的空间,是x86的windows xp。学校实验室设备,只支持ccs3.3啊
    天高云阔,风语如歌。
  • 回复 Teadross:
    会不会是虚拟机的原因,没碰到过装在虚拟机上的情况,很难判断。
    上传看一下ti\ccs\install_logs中的安装信息。
    在其他电脑上也安装试试看。
  • 回复 Nancy Wang:
    === Logging started: 2020-1-21 13:57:59 ===
    Action start 13:57:59: INSTALL.
    Action start 13:57:59: WiseGetIeVersion.
    Action ended 13:58:00: WiseGetIeVersion. Return value 1.
    Action start 13:58:00: LaunchConditions.
    Action ended 13:58:00: LaunchConditions. Return value 1.
    Action start 13:58:00: Setup_Dialog.
    Info 2898. MSSansSerif8, MS Sans Serif, 1
    Info 2898. Arial14, Arial, 1
    Info 2898. Arial10, Arial, 1
    Action ended 13:58:00: Setup_Dialog. Return value 1.
    Action start 13:58:00: FindRelatedProducts.
    Action ended 13:58:00: FindRelatedProducts. Return value 1.
    Action start 13:58:00: AppSearch.
    Action ended 13:58:00: AppSearch. Return value 1.
    Action start 13:58:00: GetPerlInfoFromRegistry.
    Action ended 13:58:00: GetPerlInfoFromRegistry. Return value 0.
    Action start 13:58:00: ValidateProductID.
    Action ended 13:58:00: ValidateProductID. Return value 1.
    Action start 13:58:00: CostInitialize.
    Action ended 13:58:00: CostInitialize. Return value 1.
    Action start 13:58:00: FileCost.
    Action ended 13:58:00: FileCost. Return value 1.
    Action start 13:58:00: IsolateComponents.
    Action ended 13:58:00: IsolateComponents. Return value 1.
    Action start 13:58:00: CostFinalize.
    Action ended 13:58:00: CostFinalize. Return value 1.
    Action start 13:58:00: MigrateFeatureStates.
    Action ended 13:58:00: MigrateFeatureStates. Return value 0.
    Action start 13:58:00: Welcome_Dialog.
    Info 2898. RequirementMet, Arial, 1
    Info 2898. RequirementNotMet, Arial, 1
    Info 2898. Arial8, Arial, 1
    Info 2898. Arial12, Arial, 1
    DEBUG: Error 2863: The control PushButton2 on dialog Installation_Type_Dialog needs the icon TypicalInstall.bmp in size 48x48, but that size is not available. Loading the first available size
    Internal Error 2863. Installation_Type_Dialog, PushButton2, TypicalInstall.bmp
    DEBUG: Error 2863: The control PushButton28 on dialog Installation_Type_Dialog needs the icon TypicalInstall.bmp in size 48x48, but that size is not available. Loading the first available size
    Internal Error 2863. Installation_Type_Dialog, PushButton28, TypicalInstall.bmp
    DEBUG: Error 2863: The control PushButton25 on dialog Installation_Type_Dialog needs the icon CustomInstall.bmp in size 48x48, but that size is not available. Loading the first available size
    Internal Error 2863. Installation_Type_Dialog, PushButton25, CustomInstall.bmp
    Info 2898. MS_Sans_Serif81, MS Sans Serif, 1
    Info 2898. MS_Sans_Serif8, MS Sans Serif, 1
    Action ended 13:58:19: Welcome_Dialog. Return value 1.
    Action start 13:58:19: Progress_Dialog.
    Action ended 13:58:19: Progress_Dialog. Return value 1.
    Action start 13:58:19: ExecuteAction.
    Action start 13:58:20: INSTALL.
    Action start 13:58:20: WiseGetIeVersion.
    Action ended 13:58:20: WiseGetIeVersion. Return value 0.
    Action start 13:58:20: LaunchConditions.
    Action ended 13:58:20: LaunchConditions. Return value 1.
    Action start 13:58:20: FindRelatedProducts.
    Action ended 13:58:20: FindRelatedProducts. Return value 0.
    Action start 13:58:20: AppSearch.
    Action ended 13:58:20: AppSearch. Return value 0.
    Action start 13:58:20: ValidateProductID.
    Action ended 13:58:20: ValidateProductID. Return value 1.
    Action start 13:58:20: CostInitialize.
    Action ended 13:58:20: CostInitialize. Return value 1.
    Action start 13:58:20: ResolveSource.
    Action ended 13:58:20: ResolveSource. Return value 1.
    Action start 13:58:20: FileCost.
    Action ended 13:58:20: FileCost. Return value 1.
    Action start 13:58:20: IsolateComponents.
    Action ended 13:58:20: IsolateComponents. Return value 1.
    Action start 13:58:20: CostFinalize.
    Action ended 13:58:20: CostFinalize. Return value 1.
    Action start 13:58:20: SetODBCFolders.
    Action ended 13:58:20: SetODBCFolders. Return value 1.
    Action start 13:58:20: MigrateFeatureStates.
    Action ended 13:58:20: MigrateFeatureStates. Return value 0.
    Action start 13:58:20: InstallValidate.
    Action ended 13:58:21: InstallValidate. Return value 1.
    Action start 13:58:21: InstallInitialize.
    Action ended 13:58:23: InstallInitialize. Return value 1.
    Action start 13:58:23: TIBuildInstallDirRegKey.
    Action ended 13:58:23: TIBuildInstallDirRegKey. Return value 0.
    Action start 13:58:23: TIBuildDisplayVersionCA.
    Action ended 13:58:23: TIBuildDisplayVersionCA. Return value 0.
    Action start 13:58:23: SetCompMgrEXEPropertyCA.
    Action ended 13:58:23: SetCompMgrEXEPropertyCA. Return value 1.
    Action start 13:58:23: CCSInstallPluginSetup.
    Action ended 13:58:23: CCSInstallPluginSetup. Return value 1.
    Action start 13:58:23: AllocateRegistrySpace.
    Action ended 13:58:23: AllocateRegistrySpace. Return value 1.
    Action start 13:58:23: ProcessComponents.
    Action ended 13:58:23: ProcessComponents. Return value 1.
    Action start 13:58:23: UnpublishComponents.
    Action ended 13:58:23: UnpublishComponents. Return value 1.
    Action start 13:58:23: UnpublishFeatures.
    Action ended 13:58:23: UnpublishFeatures. Return value 1.
    Action start 13:58:23: StopServices.
    Action ended 13:58:23: StopServices. Return value 1.
    Action start 13:58:23: DeleteServices.
    Action ended 13:58:23: DeleteServices. Return value 1.
    Action start 13:58:23: UnregisterComPlus.
    Action ended 13:58:23: UnregisterComPlus. Return value 1.
    Action start 13:58:23: SelfUnregModules.
    Action ended 13:58:23: SelfUnregModules. Return value 1.
    Action start 13:58:23: UnregisterTypeLibraries.
    Action ended 13:58:23: UnregisterTypeLibraries. Return value 1.
    Action start 13:58:23: RemoveODBC.
    Action ended 13:58:23: RemoveODBC. Return value 1.
    Action start 13:58:23: UnregisterFonts.
    Action ended 13:58:23: UnregisterFonts. Return value 1.
    Action start 13:58:23: RemoveRegistryValues.
    Action ended 13:58:23: RemoveRegistryValues. Return value 1.
    Action start 13:58:23: UnregisterClassInfo.
    Action ended 13:58:23: UnregisterClassInfo. Return value 1.
    Action start 13:58:23: UnregisterExtensionInfo.
    Action ended 13:58:23: UnregisterExtensionInfo. Return value 1.
    Action start 13:58:23: UnregisterProgIdInfo.
    Action ended 13:58:23: UnregisterProgIdInfo. Return value 1.
    Action start 13:58:23: UnregisterMIMEInfo.
    Action ended 13:58:23: UnregisterMIMEInfo. Return value 1.
    Action start 13:58:23: RemoveIniValues.
    Action ended 13:58:23: RemoveIniValues. Return value 1.
    Action start 13:58:23: RemoveShortcuts.
    Action ended 13:58:23: RemoveShortcuts. Return value 1.
    Action start 13:58:23: RemoveEnvironmentStrings.
    Action ended 13:58:23: RemoveEnvironmentStrings. Return value 1.
    Action start 13:58:23: RemoveDuplicateFiles.
    Action ended 13:58:23: RemoveDuplicateFiles. Return value 1.
    Action start 13:58:23: RemoveFiles.
    Action ended 13:58:23: RemoveFiles. Return value 1.
    Action start 13:58:23: RemoveFolders.
    Action ended 13:58:23: RemoveFolders. Return value 1.
    Action start 13:58:23: CreateFolders.
    Action ended 13:58:23: CreateFolders. Return value 1.
    Action start 13:58:23: MoveFiles.
    Action ended 13:58:23: MoveFiles. Return value 1.
    Action start 13:58:23: InstallFiles.
    Action ended 13:58:25: InstallFiles. Return value 1.
    Action start 13:58:25: DuplicateFiles.
    Action ended 13:58:25: DuplicateFiles. Return value 1.
    Action start 13:58:25: PatchFiles.
    Action ended 13:58:25: PatchFiles. Return value 1.
    Action start 13:58:25: BindImage.
    Action ended 13:58:25: BindImage. Return value 1.
    Action start 13:58:25: CreateShortcuts.
    Action ended 13:58:25: CreateShortcuts. Return value 1.
    Action start 13:58:25: RegisterClassInfo.
    Action ended 13:58:25: RegisterClassInfo. Return value 1.
    Action start 13:58:25: RegisterExtensionInfo.
    Action ended 13:58:25: RegisterExtensionInfo. Return value 1.
    Action start 13:58:25: RegisterProgIdInfo.
    Action ended 13:58:25: RegisterProgIdInfo. Return value 1.
    Action start 13:58:25: RegisterMIMEInfo.
    Action ended 13:58:25: RegisterMIMEInfo. Return value 1.
    Action start 13:58:25: WriteRegistryValues.
    Action ended 13:58:25: WriteRegistryValues. Return value 1.
    Action start 13:58:25: WriteIniValues.
    Action ended 13:58:25: WriteIniValues. Return value 1.
    Action start 13:58:25: SetARPINSTALLLOCATIONPropertyCA.
    Action ended 13:58:25: SetARPINSTALLLOCATIONPropertyCA. Return value 1.
    Action start 13:58:25: SetDosRunBatCA.
    Action ended 13:58:25: SetDosRunBatCA. Return value 1.
    Action start 13:58:25: TIDosRunSetPathCA.
    Action ended 13:58:25: TIDosRunSetPathCA. Return value 1.
    Action start 13:58:25: WriteEnvironmentStrings.
    Action ended 13:58:25: WriteEnvironmentStrings. Return value 1.
    Action start 13:58:25: RegisterFonts.
    Action ended 13:58:25: RegisterFonts. Return value 1.
    Action start 13:58:25: InstallODBC.
    Action ended 13:58:25: InstallODBC. Return value 0.
    Action start 13:58:25: RegisterTypeLibraries.
    Action ended 13:58:25: RegisterTypeLibraries. Return value 1.
    Action start 13:58:25: SetBiosUninstallerPropertyCA.
    Action ended 13:58:25: SetBiosUninstallerPropertyCA. Return value 1.
    Action start 13:58:25: ActionSetCustomActionData.
    Action ended 13:58:25: ActionSetCustomActionData. Return value 1.
    Action start 13:58:25: SetBiosInstallerPropertyCA.
    Action ended 13:58:25: SetBiosInstallerPropertyCA. Return value 1.
    Action start 13:58:25: BIOS_Install_CA.
    Action ended 13:58:25: BIOS_Install_CA. Return value 1.
    Action start 13:58:25: SelfRegModules.
    Action ended 13:58:25: SelfRegModules. Return value 1.
    Action start 13:58:25: RegisterComPlus.
    Action ended 13:58:25: RegisterComPlus. Return value 1.
    Action start 13:58:25: InstallServices.
    Action ended 13:58:25: InstallServices. Return value 1.
    Action start 13:58:25: StartServices.
    Action ended 13:58:25: StartServices. Return value 1.
    Action start 13:58:25: XDS560Install.
    Action ended 13:58:25: XDS560Install. Return value 1.
    Action start 13:58:25: RegisterUser.
    Action ended 13:58:25: RegisterUser. Return value 1.
    Action start 13:58:25: RegisterProduct.
    Action ended 13:58:25: RegisterProduct. Return value 1.
    Action start 13:58:25: PublishComponents.
    Action ended 13:58:25: PublishComponents. Return value 1.
    Action start 13:58:25: PublishFeatures.
    Action ended 13:58:25: PublishFeatures. Return value 1.
    Action start 13:58:25: PublishProduct.
    Action ended 13:58:25: PublishProduct. Return value 1.
    Action start 13:58:25: RegCCAPP.
    Action ended 13:58:25: RegCCAPP. Return value 1.
    Action start 13:58:25: SETUPinstallPlugins.
    Action ended 13:58:25: SETUPinstallPlugins. Return value 1.
    Action start 13:58:25: SetProductSKU.
    Action ended 13:58:25: SetProductSKU. Return value 1.
    Action start 13:58:25: SetupCompMgr.
    Action ended 13:58:25: SetupCompMgr. Return value 1.
    Action start 13:58:25: xds100usbSetupEXE.
    Action ended 13:58:25: xds100usbSetupEXE. Return value 1.
    Action start 13:58:25: InstallFinalize.
    天高云阔,风语如歌。
  • 回复 Nancy Wang:
    并且死机之后强制重启会发现多了一个设备要我安装驱动,可以我不知道这个驱动在哪里安装
    天高云阔,风语如歌。
  • 回复 Nancy Wang:
    这个是截图
    天高云阔,风语如歌。
  • 回复 Teadross:
    参考这个帖子看一下,跟你的情况类似,并且给出了解决办法。
    e2e.ti.com/.../12824
  • 回复 Nancy Wang:
    感谢。问题解决了,安装完成了。这里还有一个问题:按照提示,我安装时没有勾选X560的驱动。请问我如何额外安装该驱动?
    天高云阔,风语如歌。
  • 回复 Nancy Wang:
    您好,请问如何独立安装X560的驱动程序呢?
    天高云阔,风语如歌。
