工程师您好:
我最近调试一个使用IPC的程序,C6657的核0是一个TCP网络,核1是处理核。核1需要使用malloc申请大量内存空间,但是会默认将内存申请到L2SRAM中,超出了内存大小。于是注释掉了biso.heapsize行,使用HeapMem创建一个堆供核1的malloc使用,但是修改Memory.defaultHeapInstance后程序有时加载后直接出错,或者运行时也不能双核协调运行,请问可能是什么问题
cfg配置如下
var System = xdc.useModule('xdc.runtime.System');
var SysStd = xdc.useModule('xdc.runtime.SysStd');
var Fan = xdc.useModule('Tronlong.Driver.Fan');
System.SupportProxy = SysStd;
/* 存储空间分配 */
Program.sectMap["SystemHeap"] = "DDR3_CORE0";
Program.sectMap[".const"] = "L2SRAM";
Program.sectMap[".switch"] = "L2SRAM";
Program.sectMap[".cinit"] = "L2SRAM";
Program.sectMap[".vecs"] = "L2SRAM";
Program.sectMap[".DDR3_0"] = "DDR3_CORE0";
Program.sectMap[".DDR3_1"] = "DDR3_CORE1";
var BIOS = xdc.useModule('ti.sysbios.BIOS');
//BIOS.heapSize = 32768;
/* 创建任务 */
var Task = xdc.useModule('ti.sysbios.knl.Task');
var tsk0 = Task.create('&tsk0_func');
tsk0.instance.name = "tsk0";
/* 创建信号量 */
var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
Program.global.receive = Semaphore.create(1);
Program.global.process = Semaphore.create(0);
Program.global.sendimg = Semaphore.create(0);
Program.global.mutex = Semaphore.create(1);
/* 配置核心名 */
var MultiProc = xdc.useModule('ti.sdo.utils.MultiProc');
var procNameAry = MultiProc.getDeviceProcNames();
MultiProc.setConfig(Program.global.procName, procNameAry);
/* IPC 配置 */
var Ipc = xdc.useModule('ti.sdo.ipc.Ipc');
var Notify = xdc.useModule('ti.sdo.ipc.Notify'); /* Notify */
var GateMP = xdc.useModule('ti.sdo.ipc.GateMP'); /* GateMP */
var SharedRegion = xdc.useModule('ti.sdo.ipc.SharedRegion'); /* shared region */
var MessageQ = xdc.useModule('ti.sdo.ipc.MessageQ'); /* MessageQ */
var HeapBufMP = xdc.useModule('ti.sdo.ipc.heaps.HeapBufMP');
Ipc.procSync = Ipc.ProcSync_ALL; /* Ipc_start 里同步所有核心*/
Ipc.sr0MemorySetup = true;
GateMP.maxRuntimeEntries = 4;
GateMP.RemoteCustom1Proxy = xdc.useModule('ti.sdo.ipc.gates.GateMPSupportNull');
/* 配置 SharedRegion #0 (IPC) */
var SHAREDMEM = 0x80000000;
var SHAREDMEMSIZE = 0x02000000;
SharedRegion.setEntryMeta(0,
{ base: SHAREDMEM,
len: SHAREDMEMSIZE,
ownerProcId: 0,
isValid: true,
{ base: SHAREDMEM,
len: SHAREDMEMSIZE,
ownerProcId: 0,
isValid: true,
for (var i = 0; i < MultiProc.numProcessors; i++) {
Ipc.setEntryMeta({
remoteProcId: i,
setupMessageQ: true,
Ipc.setEntryMeta({
remoteProcId: i,
var Startup = xdc.useModule('xdc.runtime.Startup');
/******************************************************NDK 配置******************************************************/
Program.stack = 8192;
BIOS.startupFxns = ['&CacheInit'];
//启动时调用初始化函数
var Hwi = xdc.useModule('ti.sysbios.family.c64p.Hwi');
var HeapMem = xdc.useModule('ti.sysbios.heaps.HeapMem');
var SystemHeapParams = new HeapMem.Params;
SystemHeapParams.size = 16*16 *1024;
SystemHeapParams.sectionName = "SystemHeap";
Program.global.SystemHeap = HeapMem.create(SystemHeapParams);
var Memory = xdc.useModule('xdc.runtime.Memory')
Memory.defaultHeapInstance = Program.global.SystemHeap;
var Global = xdc.useModule('ti.ndk.config.Global');
Global.networkOpenHook = '&NetOpenHook';
Global.networkCloseHook = '&NetCloseHook';
Global.networkIPAddrHook = '&NetIPAddrChange';
var Ip = xdc.useModule('ti.ndk.config.Ip');
Ip.hostName = "TMS320C665x";
Ip.RestartIPTerm = true;
Ip.autoIp = false;
Ip.address = "192.168.1.30";
Ip.mask = "255.255.255.0";
Ip.autoIp = false;
/* UIA */
var Logging = xdc.useModule('ti.uia.sysbios.LoggingSetup');
/* 实时分析 */
Logging.sysbiosHwiLogging = true;
Logging.sysbiosSwiLogging = true;
Logging.sysbiosHwiLoggingRuntimeControl = true;
Logging.sysbiosSwiLoggingRuntimeControl = true;
Logging.eventUploadMode = Logging.UploadMode_JTAGRUNMODE;
Task.defaultStackSize = 32768;
Task.defaultStackHeap = null;
Task.checkStackFlag = false;
cmd文件:
MEMORY
IPC o = 0x80000000 l = 0x10000000 /* 256MB 多核通信专用内存 */
DDR3_CORE0 o = 0x90000000 l = 0x08000000 /* 128MB 核心 0 专用 DDR3 内存 */
DDR3_CORE1 o = 0x98000000 l = 0x08000000 /* 128MB 核心 1 专用 DDR3 内存 */
SECTIONS
{ /* C 语言入口 */
.text:_c_int00 > MSMCSRAM START(BootMagic)
{ /* C 语言入口 */
