做k1_stk_v1.1 emif 例程时 编译后出现"../src/EMIF_main.c", line 125: error #20: identifier "CSLSIZE_PSC_PD_ALWAYSON" is undefined
* Copyright (C) 2012 Texas Instruments Incorporated. *
* All Rights Reserved *
* GENERAL DISCLAIMER *
* All software and related documentation is provided "AS IS" and without *
* warranty or support of any kind and Texas Instruments expressly disclaims*
* all other warranties, express or implied, including, but not limited to, *
* the implied warranties of merchantability and fitness for a particular *
* purpose. Under no circumstances shall Texas Instruments be liable for *
* any incidental, special or consequential damages that result from the *
* use or inability to use the software or related documentation, even if *
* Texas Instruments has been advised of the liability. *
This example shows EMIF operations:
1. NAND FLASH test, Verified on NAND512R3A2DZA6E on Shannon EVM,
MT29F1G08ABBDAHC on Appleton EVM.
2. NOR FLASH test, Verified on JS28F256M29EW on a customer's board.
* Created by : *
* Brighton Feng *
* Texas Instruments *
* Jan 5, 2012 *
#include <stdio.h>
#include <string.h>
#include "KeyStone_common.h"
#include "Keystone_DDR_Init.h"
#include "KeyStone_EMIF16_init.h"
#include "EMIF_NOR_FLASH_test.h"
#include "EMIF_NAND_FLASH_test.h"
* Created by : *
* Brighton Feng *
* Jan 5, 2012 *
#include <stdio.h>
#include <string.h>
/*select between NAND FLASH or NOR FLASH test*/
#define NAND_FLASH_TEST 1
#define FLASH_TEST_BUFFER_SIZE (1*1024*1024)
#pragma DATA_SECTION(testBuf,".far:testBuf")
Uint8 testBuf[FLASH_TEST_BUFFER_SIZE];
EMIF16_CE_Config gNorCeCfg; /*the configuration for the CE of NOR FLASH*/
EMIF16_CE_Config gNandCeCfg;/*the configuration for the CE of NAND FLASH*/
EMIF16_Config gEmif16Cfg;
void EMIF_init()
memset(&gNorCeCfg, 0, sizeof(gNorCeCfg));
memset(&gNandCeCfg, 0, sizeof(gNandCeCfg));
memset(&gEmif16Cfg, 0, sizeof(gEmif16Cfg));
/*configuraiton for the CE of NOR FLASH*/
gNorCeCfg.busWidth= EMIF_BUS_16BIT;
gNorCeCfg.opMode = NOR_ASRAM_MODE;
gNorCeCfg.strobeMode = SS_STROBE;
gNorCeCfg.waitMode = EMIF_WAIT_NONE;
gNorCeCfg.wrSetup = CSL_EMIF16_A0CR_WSETUP_RESETVAL;
gNorCeCfg.wrStrobe = CSL_EMIF16_A0CR_WSTROBE_RESETVAL;
gNorCeCfg.wrHold= CSL_EMIF16_A0CR_WHOLD_RESETVAL;
gNorCeCfg.rdSetup= CSL_EMIF16_A0CR_RSETUP_RESETVAL;
gNorCeCfg.rdStrobe= CSL_EMIF16_A0CR_RSTROBE_RESETVAL;
gNorCeCfg.rdHold= CSL_EMIF16_A0CR_RHOLD_RESETVAL;
gNorCeCfg.turnAroundCycles= CSL_EMIF16_A0CR_TA_RESETVAL;
gNorCeCfg.nor_pg_Cfg= NULL;
void EMIF_init()
/*configuraiton for the CE of NAND FLASH*/
gNandCeCfg.busWidth= EMIF_BUS_8BIT;
gNandCeCfg.opMode = NAND_MODE;
gNandCeCfg.strobeMode = SS_STROBE;
gNandCeCfg.waitMode = EMIF_WAIT_NONE;
/*timing configuration for NAND512R3A2DZA6E*/
#if 1
gNandCeCfg.wrSetup = 1;//CSL_EMIF16_A0CR_WSETUP_RESETVAL,
gNandCeCfg.wrStrobe = 4;//CSL_EMIF16_A0CR_WSTROBE_RESETVAL,
gNandCeCfg.wrHold= 5;//CSL_EMIF16_A0CR_WHOLD_RESETVAL,
gNandCeCfg.rdSetup= 1;//CSL_EMIF16_A0CR_RSETUP_RESETVAL
gNandCeCfg.rdStrobe= 7;//CSL_EMIF16_A0CR_RSTROBE_RESETVAL
gNandCeCfg.rdHold= 2;//CSL_EMIF16_A0CR_RHOLD_RESETVAL
#else
gNandCeCfg.wrSetup = CSL_EMIF16_A0CR_WSETUP_RESETVAL;
gNandCeCfg.wrStrobe = CSL_EMIF16_A0CR_WSTROBE_RESETVAL;
gNandCeCfg.wrHold= CSL_EMIF16_A0CR_WHOLD_RESETVAL;
gNandCeCfg.rdSetup= CSL_EMIF16_A0CR_RSETUP_RESETVAL;
gNandCeCfg.rdStrobe= CSL_EMIF16_A0CR_RSTROBE_RESETVAL;
gNandCeCfg.rdHold= CSL_EMIF16_A0CR_RHOLD_RESETVAL;
#endif
gNandCeCfg.turnAroundCycles= CSL_EMIF16_A0CR_TA_RESETVAL;
gNandCeCfg.nor_pg_Cfg= NULL;
#if 1
#else
#endif
#if NAND_FLASH_TEST
gEmif16Cfg.ceCfg[0] = &gNandCeCfg;
#else
gEmif16Cfg.ceCfg[0] = &gNorCeCfg;
#endif
#else
#endif
gEmif16Cfg.wait0Polarity= EMIF_LOW_WAIT;
gEmif16Cfg.wait1Polarity= EMIF_LOW_WAIT;
gEmif16Cfg.maxWait = CSL_EMIF16_AWCCR_MAXEXTWAIT_RESETVAL;
KeyStone_EMIF16_init(&gEmif16Cfg);
void main()
/*enable TSC, memory protection interrupts, EDC for internal RAM;
clear cache; protect L1 as cache*/
KeyStone_common_CPU_init();
/*print device information.
Enable memory protection interrupts, EDC for MSMC RAM*/
KeyStone_common_device_init();
//enable exception handling
KeyStone_Exception_cfg(TRUE);
// System init
CACHE_setL1PSize(CACHE_L1_32KCACHE);
CACHE_setL1DSize(CACHE_L1_32KCACHE);
CACHE_setL2Size(CACHE_128KCACHE);
if(C6678_EVM==gDSP_board_type)
//DSP core speed: 100*10/1=1000MHz
KeyStone_main_PLL_init(100, 10, 1);
//On Shannon, EMIF belong to clock domain 3 which need be enabled
KeyStone_enable_PSC_module(CSLSIZE_PSC_PD_ALWAYSON, 3);
else if(TCI6614_EVM==gDSP_board_type)
//DSP core speed: 122.88*236/29= 999.9889655MHz
KeyStone_main_PLL_init(122.88, 236, 29);
else
puts("Unknown DSP board type!");
return;
else
return;
//DDR init 66.66667*20/1= 1333
KeyStone_DDR_init (66.66667, 20, 1, NULL);
EMIF_init();
#if NAND_FLASH_TEST
NAND_FLASH_test((Uint32)testBuf, FLASH_TEST_BUFFER_SIZE);
#else
NOR_FLASH_test((Uint32)testBuf, FLASH_TEST_BUFFER_);
#endif
#else
#endif
puts("FLASH test complete.");
