28377D DSP CLA运算问题
在CLA里进行运算报这个警告,请问一下如何清除,对我的运算结果会有啥影响吗?
Comparison operation uses integer comparison instruction, which does not operate properly for values that would overflow subtraction.  Use --cla_signed_compare_workaround=on to have the compiler work around this issue.
