我们使用的是am5729芯片,硬件板公司自己制作,设备树文件参考am572x-idk,但是系统起来后,为什么没有生成 /dev/fb0节点
与lcd相关的设备树节点如下:
lcd_bl: backlight {
compatible = "pwm-backlight";
pwms = <&ecap0 0 50000 0>;
brightness-levels = <0 51 53 56 62 75 101 152 255>;
default-brightness-level = <8>;
lcd: display {
compatible = "panel-dpi";
enable-gpios = <&gpio3 30 GPIO_ACTIVE_HIGH>;
backlight = <&lcd_bl>;*/
label = "lcd";
panel-timing {
clock-frequency = <33300000>;
hactive = <800>;
vactive = <480>;
hfront-porch = <210>;
hback-porch = <46>;
hsync-len = <20>;
vfront-porch = <22>;
vback-porch = <23>;
vsync-len = <10>;
hsync-active = <1>;
vsync-active = <1>;
de-active = <0>;
pixelclk-active = <0>;
port {
lcd_in: endpoint {
remote-endpoint = <&dpi_out>;
&dss {
status = "okay";
vdda_video-supply = <&ldoln_reg>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port {
reg = <1>;
dpi_out: endpoint {
data-lines = <24>;
remote-endpoint = <&lcd_in>;
