"VLIB_convertUYVYint_to_LABpl_i.c", line 17 (approximate): warning: relocation
from function "VLIB_convertUYVYint_to_LABpl" to symbol "__fixdi" overflowed;
the 22-bit relocated address 0xe0f578 is too large to encode in the 21-bit
signed PC-Relative field (type = 'R_C60PCR21' (82), file =
"../../libs/vlib.l64p<VLIB_convertUYVYint_to_LABpl_i.obj>", offset =
0x00001cf0, section = ".text")
这个在DSP端计算点数比较多时会提示这个警告,数据点少不会提示,请问具体的怎么解决,在Linux下怎么修改
