1.使用的是ccs6.1.2版本,编译器配置为GNU v4.9.3,目标芯片是am4378
starterware包被放在SYSBIOSSDK-IND-SITARA软件包中
www.ti.com.cn/.../sysbiossdk-ind-sitara
2.向ccs工程中导入bootloader工程,依照提示又导入依赖的6个工程:
依照上图中的要求,逐个修改各依赖工程的编译配置
3.编译bootloader工程,结果报错:
**** Build of configuration am43xx_boot_mmcsd_debug for project bootloader ****
"D:\\ti\\ccsv6\\utils\\bin\\gmake" -j 4 -s -k all
'Building file: D:/ti/starterware/examples/mmcsd/hsmmcsd_app_pol.c'
'Building file: D:/ti/starterware/examples/gpio/gpio_app.c'
'Building file: D:/ti/starterware/bootloader/src/am43xx/sbl_am43xx_platform.c'
'Building file: D:/ti/starterware/bootloader/src/am43xx/sbl_am43xx_platform_ddr.c'
'Invoking: GNU Compiler'
'Finished building: D:/ti/starterware/examples/gpio/gpio_app.c'
'Finished building: D:/ti/starterware/examples/mmcsd/hsmmcsd_app_pol.c'
'Finished building: D:/ti/starterware/bootloader/src/am43xx/sbl_am43xx_platform.c'
'Finished building: D:/ti/starterware/bootloader/src/am43xx/sbl_am43xx_platform_ddr.c'
'Building file: D:/ti/starterware/bootloader/src/sbl_copy.c'
'Building file: D:/ti/starterware/bootloader/src/am43xx/sbl_am43xx_platform_pll.c'
'Building file: D:/ti/starterware/bootloader/src/sbl_main.c'
'Building file: D:/ti/starterware/bootloader/src/sbl_mmcsd.c'
D:/ti/starterware/bootloader/src/sbl_main.c: In function 'main':
D:/ti/starterware/bootloader/src/sbl_main.c:88:14: warning: variable 'status' set but not used [-Wunused-but-set-variable]
uint32_t status;
'Finished building: D:/ti/starterware/bootloader/src/sbl_copy.c'
'Finished building: D:/ti/starterware/bootloader/src/sbl_main.c'
'Finished building: D:/ti/starterware/bootloader/src/sbl_mmcsd.c'
'Finished building: D:/ti/starterware/bootloader/src/am43xx/sbl_am43xx_platform_pll.c'
'Building target: ../../../binary/bootloader/bin/am43xx-evm/ccs/bootloader_boot_mmcsd_a9host_debug.out'
'Invoking: GNU Linker'
d:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe:../../../examples/gcc/am43xx_boot_ccs.lds:50: warning: redeclaration of memory region `DDR0'
d:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe: ../../../binary/bootloader/bin/am43xx-evm/ccs/bootloader_boot_mmcsd_a9host_debug.out section `.stack' will not fit in region `OCMCRAM'
d:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe: region `OCMCRAM' overflowed by 61784 bytes
collect2.exe: error: ld returned 1 exit status
gmake: *** [../../../binary/bootloader/bin/am43xx-evm/ccs/bootloader_boot_mmcsd_a9host_debug.out] Error 1
gmake: Target `all' not remade because of errors.
**** Build Finished ****
请问这是什么原因啊
