打开CCS错误,请问有遇到过吗?显示下面的内容:
!SESSION 2018-03-23 17:08:45.110 -----------------------------------------------
eclipse.buildId=4.6.0.I20160606-1100
java.version=1.8.0_112
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Framework arguments: -product com.ti.ccstudio.branding.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product
!ENTRY org.eclipse.osgi 4 0 2018-03-23 17:08:47.890
!MESSAGE Application error
!STACK 1
java.lang.ArrayIndexOutOfBoundsException
at java.lang.System.arraycopy(Native Method)
at java.util.Arrays.copyOfRange(Arrays.java:3485)
at java.util.Arrays.copyOfRange(Arrays.java:3441)
at org.eclipse.ui.internal.ide.ChooseWorkspaceDialog.lambda$7(ChooseWorkspaceDialog.java:380)
at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193)
at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1374)
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481)
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471)
at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708)
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:499)
at org.eclipse.ui.internal.ide.ChooseWorkspaceDialog.createUniqueWorkspaceNameMap(ChooseWorkspaceDialog.java:382)
at org.eclipse.ui.internal.ide.ChooseWorkspaceDialog.createRecentWorkspacesComposite(ChooseWorkspaceDialog.java:325)
at org.eclipse.ui.internal.ide.ChooseWorkspaceDialog.createDialogArea(ChooseWorkspaceDialog.java:176)
at org.eclipse.jface.dialogs.TitleAreaDialog.createContents(TitleAreaDialog.java:158)
at org.eclipse.jface.window.Window.create(Window.java:426)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1095)
at org.eclipse.jface.window.Window.open(Window.java:783)
at org.eclipse.ui.internal.ide.ChooseWorkspaceDialog.prompt(ChooseWorkspaceDialog.java:114)
at org.eclipse.ui.internal.ide.application.IDEApplication.promptForWorkspace(IDEApplication.java:342)
at org.eclipse.ui.internal.ide.application.IDEApplication.checkInstanceLocation(IDEApplication.java:261)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:128)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
