在程序中试过两种方式,连续的和 one-short ,连续的得不到正确的结果,one-short可以,但是只能进入中断 函数一次,后续Ecap reg 就不在捕获寄存器了,代码如下
void ECaptureConfig(volatile struct ECAP_REGS *reg)
reg-> ECEINT.all = 0x0000; // Disable all capture __interrupts
reg-> ECCLR.all = 0xFFFF; // Clear all CAP __interrupt flags
reg-> ECCTL1.bit.CAPLDEN = 0; // Disable CAP1-CAP4 register loads
reg-> ECCTL2.bit.TSCTRSTOP = 0; // Make sure the counter is stopped
// Configure peripheral registers
// reg-> ECCTL1.bit.FREE_SOFT =2;//free run
reg-> ECCTL2.bit.CONT_ONESHT = 1; // One-shot
reg-> ECCTL2.bit.STOP_WRAP = 3; // Stop at 4 events
reg-> ECCTL1.bit.CAP1POL = EC_RISING; // Falling edge
reg-> ECCTL1.bit.CAP2POL = EC_FALLING; //1= Rising edge
reg-> ECCTL1.bit.CAP3POL = EC_RISING; //0= Falling edge
reg-> ECCTL1.bit.CAP4POL = EC_FALLING; // Rising edge
reg-> ECCTL1.bit.CTRRST1 = 0; // Difference operation
reg-> ECCTL1.bit.CTRRST2 = 0; // Difference operation
reg-> ECCTL1.bit.CTRRST3 = 0; // Difference operation
reg-> ECCTL1.bit.CTRRST4 = 0; // Difference operation
reg-> ECCTL2.bit.SYNCI_EN = 0; // DisEnable sync in
reg-> ECCTL2.bit.SYNCO_SEL = 0; // Pass through
reg-> ECCTL1.bit.CAPLDEN = 1; // Enable capture units
//need change for different cap
reg->ECCTL2.bit.REARM=1;
reg-> ECEINT.bit.CEVT4 = 1; // 1 events = __interrupt
reg-> ECEINT.bit.CTROVF =1;
reg-> ECCTL2.bit.TSCTRSTOP = 1; // Start Counter
void EcapInit(void)
ECaptureConfig(&ECap1Regs);
__interrupt void ecap1_isr(void)
uint32_t prdio =0,duty=0;
PieCtrlRegs.PIEACK.all = PIEACK_GROUP4;
if(ECap1Regs.ECFLG.bit.CTROVF == 1)
ECap1Regs.ECCLR.bit.CTROVF = 1;
ECap1Regs.ECCLR.bit.INT = 1;
if(ECap1Regs.ECFLG.bit.CEVT4 == 1)
ECap1Regs.ECCLR.bit.CEVT1 = 1;
ECap1Regs.ECCLR.bit.CEVT2 = 1;
ECap1Regs.ECCLR.bit.CEVT3 = 1;
ECap1Regs.ECCLR.bit.CEVT4 = 1;
prdio= ECap1Regs.CAP3 - ECap1Regs.CAP1;
duty = ECap1Regs.CAP2 - ECap1Regs.CAP1;
if(prdio >0)
FreData[0].frequen = 150000000/prdio;
FreData[0].duty = duty*100/prdio;
}else
FreData[0].frequen = 0;
FreData[0].duty = 0;
// // arm one-shot
ECap1Regs.ECCTL2.bit.TSCTRSTOP =0;
// ECap1Regs.ECCTL2.bit.REARM = 1;
#endi
上电后第一次进中断函数的频率值和占空比都是正常的,但捕获不会再次发生, 如果把中断的这句 ECap1Regs.ECCTL2.bit.REARM = 1; 加上,CEVT1~4 会立刻置位,ECAp1~4 的值和TSCTR的值相等,而且在中断函数 中无法清零。 我想持续读取方波的频率应该怎么办?
