现有程序c语言:
void qwer(void)
switch(op)
case 0: tyui0();break;
case 1: tyui1();break;
case 2: tyui2();break;
case 3: tyui3();break;
void tyui0(void)
tyui = 0;
void tyui1(void)
tyui = 1;
void tyui2(void)
tyui = 2;
void tyui3(void)
tyui = 3;
编译后的汇编:
;* FNAME: _qwer FR SIZE: 0 *
;* FUNCTION ENVIRONMENT *
;* FUNCTION PROPERTIES *
;* 0 Parameter, 0 Auto, 0 SOE *
_qwer:
.dwcfi cfa_offset, -2
.dwcfi save_reg_to_mem, 26, 0
.dwpsn file "../28377Dtest/LGFCPU2_main.c",line 84,column 5,is_stmt,isa 0
B $C$L6,UNC ; [CPU_ALU] |84|
; branch occurs ; [] |84|
$C$L2:
.dwpsn file "../28377Dtest/LGFCPU2_main.c",line 86,column 13,is_stmt,isa 0
$C$DW$41 .dwtag DW_TAG_TI_branch
.dwattr $C$DW$41, DW_AT_low_pc(0x00)
.dwattr $C$DW$41, DW_AT_name("_tyui0")
.dwattr $C$DW$41, DW_AT_TI_call
$C$L2:
LCR #_tyui0 ; [CPU_ALU] |86|
; call occurs [#_tyui0] ; [] |86|
.dwpsn file "../28377Dtest/LGFCPU2_main.c",line 86,column 21,is_stmt,isa 0
B $C$L7,UNC ; [CPU_ALU] |86|
; branch occurs ; [] |86|
$C$L3:
.dwpsn file "../28377Dtest/LGFCPU2_main.c",line 87,column 13,is_stmt,isa 0
$C$DW$42 .dwtag DW_TAG_TI_branch
.dwattr $C$DW$42, DW_AT_low_pc(0x00)
.dwattr $C$DW$42, DW_AT_name("_tyui1")
.dwattr $C$DW$42, DW_AT_TI_call
$C$L3:
LCR #_tyui1 ; [CPU_ALU] |87|
; call occurs [#_tyui1] ; [] |87|
.dwpsn file "../28377Dtest/LGFCPU2_main.c",line 87,column 21,is_stmt,isa 0
B $C$L7,UNC ; [CPU_ALU] |87|
; branch occurs ; [] |87|
$C$L4:
.dwpsn file "../28377Dtest/LGFCPU2_main.c",line 88,column 13,is_stmt,isa 0
$C$DW$43 .dwtag DW_TAG_TI_branch
.dwattr $C$DW$43, DW_AT_low_pc(0x00)
.dwattr $C$DW$43, DW_AT_name("_tyui2")
.dwattr $C$DW$43, DW_AT_TI_call
$C$L4:
LCR #_tyui2 ; [CPU_ALU] |88|
; call occurs [#_tyui2] ; [] |88|
.dwpsn file "../28377Dtest/LGFCPU2_main.c",line 88,column 21,is_stmt,isa 0
B $C$L7,UNC ; [CPU_ALU] |88|
; branch occurs ; [] |88|
$C$L5:
.dwpsn file "../28377Dtest/LGFCPU2_main.c",line 89,column 13,is_stmt,isa 0
$C$DW$44 .dwtag DW_TAG_TI_branch
.dwattr $C$DW$44, DW_AT_low_pc(0x00)
.dwattr $C$DW$44, DW_AT_name("_tyui3")
.dwattr $C$DW$44, DW_AT_TI_call
$C$L5:
LCR #_tyui3 ; [CPU_ALU] |89|
; call occurs [#_tyui3] ; [] |89|
.dwpsn file "../28377Dtest/LGFCPU2_main.c",line 89,column 21,is_stmt,isa 0
B $C$L7,UNC ; [CPU_ALU] |89|
; branch occurs ; [] |89|
$C$L6:
MOVW DP,#_op ; [CPU_ARAU]
MOV AL,@_op ; [CPU_ALU] |84|
B $C$L2,EQ ; [CPU_ALU] |84|
; branchcc occurs ; [] |84|
CMPB AL,#1 ; [CPU_ALU] |84|
B $C$L3,EQ ; [CPU_ALU] |84|
CMPB AL,#2 ; [CPU_ALU] |84|
B $C$L4,EQ ; [CPU_ALU] |84|
CMPB AL,#3 ; [CPU_ALU] |84|
B $C$L5,EQ ; [CPU_ALU] |84|
B $C$L7,UNC ; [CPU_ALU] |84|
$C$L7:
$C$DW$45 .dwtag DW_TAG_TI_branch
.dwattr $C$DW$45, DW_AT_low_pc(0x00)
.dwattr $C$DW$45, DW_AT_TI_return
$C$L6:
$C$L7:
LRETR ; [CPU_ALU]
; return occurs ; []
.dwattr $C$DW$40, DW_AT_TI_end_file("../28377Dtest/LGFCPU2_main.c")
.dwattr $C$DW$40, DW_AT_TI_end_line(0x5b)
.dwattr $C$DW$40, DW_AT_TI_end_column(0x01)
.dwendentry
.dwendtag $C$DW$40
.dwendentry
.dwendtag $C$DW$40
.sect ".text"
.clink
.global _tyui0
.clink
.global _tyui0
$C$DW$46 .dwtag DW_TAG_subprogram
.dwattr $C$DW$46, DW_AT_name("tyui0")
.dwattr $C$DW$46, DW_AT_low_pc(_tyui0)
.dwattr $C$DW$46, DW_AT_high_pc(0x00)
.dwattr $C$DW$46, DW_AT_TI_symbol_name("_tyui0")
.dwattr $C$DW$46, DW_AT_external
.dwattr $C$DW$46, DW_AT_TI_begin_file("../28377Dtest/LGFCPU2_main.c")
.dwattr $C$DW$46, DW_AT_TI_begin_line(0x5c)
.dwattr $C$DW$46, DW_AT_TI_begin_column(0x06)
.dwattr $C$DW$46, DW_AT_TI_max_frame_size(-2)
.dwpsn file "../28377Dtest/LGFCPU2_main.c",line 93,column 1,is_stmt,address _tyui0,isa 0
.dwfde $C$DW$CIE, _tyui0
28377D编写的c语言switch语句如何编译成汇编的跳转表例如LC*XAR7或LCR*XARn?
