一、现象描述
280049 用的是 ADC 的A1 A2 和C0口 进行adc 转换 目前 A2和C0 转换都是正常的,但 A1的转换结果和C0 保持一致,不管这两个端口输入信号异同,A1的结果 同C0 ,C0 的结果是正确的。
触发是利用PWM1触发的,每次触发能连续转换这三路ADC 然后能进中断,读取信息。
二、程序代码
I_OUT as PV current output cpu_pin_9_A2 homologous 100pin as 9pin 64插脚
ADC_Vbus as PV Voltage cpu_pin_12_C0 homologous 100pin as 19pin 28插脚
ADC_Vlink as high bus voltage cpu_pin_14_A1 homologous 100pin as 22pin 30插脚
// Setup VREF as internal
ADC_setVREF(ADCA_BASE, ADC_REFERENCE_INTERNAL, ADC_REFERENCE_3_3V);
ADC_setVREF(ADCC_BASE, ADC_REFERENCE_INTERNAL, ADC_REFERENCE_3_3V);
// Set ADCCLK divider to /4
ADC_setPrescaler(ADCA_BASE, ADC_CLK_DIV_4_0);
ADC_setPrescaler(ADCC_BASE, ADC_CLK_DIV_4_0);
// Set pulse positions to late
// ADC_setInterruptPulseMode(ADCA_BASE, ADC_PULSE_END_OF_CONV);
// ADC_setInterruptPulseMode(ADCC_BASE, ADC_PULSE_END_OF_CONV);
//ADC_disableContinuousMode(ADCA_BASE,ADC_INT_NUMBER1);
// 是ADC模块的基地址;socNumber是转换开始时的编号;触发将导致SOC的源;参数通道是与输入信号相关联的数字;sampleWindow是获取窗口的持续时间。
ADC_setupSOC(ADCA_BASE,ADC_SOC_NUMBER2, //ADC 需要转换的通道 PV_I
ADC_TRIGGER_EPWM1_SOCA, //ADC 触发
ADC_CH_ADCIN2, // A2 参数通道是与输入信号相关联的数字;
15); //Time
ADC_setupSOC(ADCC_BASE,ADC_SOC_NUMBER0, //ADC 需要转换的通道 PV_V
ADC_CH_ADCIN0, // C0 参数通道是与输入信号相关联的数字;
10); //转换 Time
ADC_setupSOC(ADCA_BASE, ADC_SOC_NUMBER1, //ADC 需要转换的通道 High_VBSU
ADC_CH_ADCIN1, // A1 参数通道是与输入信号相关联的数字;
24); //Time
// Power up the ADC and then delay for 1 ms
ADC_enableConverter(ADCA_BASE);
ADC_enableConverter(ADCC_BASE);
// DEVICE_DELAY_US(1000);
// initADCSOC - Function to configure ADCA's SOC0 to be triggered by ePWM1.
void initADCSOC(void)
// Configure burst mode for SOCs
ADC_enableBurstMode(ADCA_BASE);
ADC_setBurstModeConfig(ADCA_BASE, ADC_TRIGGER_EPWM1_SOCA,3);
// Set SOC0 to set the interrupt 1 flag. Enable the interrupt and make sure its flag is cleared.
ADC_setInterruptSource(ADCA_BASE, ADC_INT_NUMBER1, ADC_SOC_NUMBER1);//Set ADCA SOC1 to set the interrupt 1 flag
ADC_enableInterrupt(ADCA_BASE, ADC_INT_NUMBER1);
ADC_clearInterruptStatus(ADCA_BASE, ADC_INT_NUMBER1);
EPWM_enableADCTrigger(EPWM1_BASE, EPWM_SOC_A);//ENable ad trigger 选择PWM1 触发ADC
EPWM_setADCTriggerSource(EPWM1_BASE,EPWM_SOC_A,EPWM_SOC_TBCTR_ZERO);//时基计数器等于零
EPWM_setADCTriggerEventPrescale(EPWM1_BASE,EPWM_SOC_A,1);//为每个预分测单元生成SOC脉冲,多达15个事件
Interrupt_enable(INT_ADCA1);
// adcA1ISR - ADC A Interrupt 1 ISR
__interrupt void adcA1ISR(void)
// Add the latest result to the buffer resultBase是ADC结果的基地址 socNumber是转换开始时的编号
PV_IADResults[index1++] = ADC_readResult(ADCARESULT_BASE, ADC_SOC_NUMBER2);//A
PV_VADResults[index2++] = ADC_readResult(ADCCRESULT_BASE, ADC_SOC_NUMBER0);//A
H_VLinkADResults[index3++] = ADC_readResult(ADCARESULT_BASE, ADC_SOC_NUMBER8);//C
// Set the bufferFull flag if the buffer is full
if(RESULTS_BUFFER_SIZE <= index1)
index1 = 0;index2=0;index3=0;
bufferFull = 1;
// Clear the interrupt flag清除中断标志
// Check if overflow has occurred 检查是否发生溢出
if(true == ADC_getInterruptOverflowStatus(ADCA_BASE, ADC_INT_NUMBER1))
ADC_clearInterruptOverflowStatus(ADCA_BASE, ADC_INT_NUMBER1);
// Acknowledge the interrupt
Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP1);
三、一直没有查出问题,硬件没有问题
