TIDM-1000联机调试掉线
在用官网的例程跑TIEVM-VIENNARECT过程中,联机调试会出现掉线情况,且有时点击run后报错:
C28xx_CPU1: Error: (Error -1044 @ 0x0) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 9.1.0.00001)
C28xx_CPU1: Trouble Halting Target CPU: (Error -1135 @ 0x8231A) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 9.1.0.00001)
C28xx_CPU1: Unable to determine target status after 20 attempts
C28xx_CPU1: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
如何解决这个问题?
1 个回复
