导入工程时报错:
Error: Import failed for project 'UIBOARD_TEST' because its compiler definition is not available. Please install the MSP430v16.9 compiler before importing this project - click 'View > CCS App Center' to check if compiler updates are available, or install the compiler manually and register it with CCS through 'Preferences > CCS > Build > Compilers'.
