请问TI工程师:
我使用MSP432P4011 处理器 今天 因为调试程序 下载一个MSP432P401R的程序 调试
发现再连接 MSP432P4011 就不再能编程调试烧写
报错如下:
CORTEX_M4_0: * WARNING *: The connected device is not MSP432P4011
CORTEX_M4_0: GEL Output: Memory Map Initialization Complete
CORTEX_M4_0: GEL Output: Halting Watchdog Timer
CORTEX_M4_0: Error initializing flash programming: Your XMS432P401R material is no longer supported. We recommend you moving to production-quality MSP432P401R/M silicon by ordering samples at www.ti.com/product/MSP432P401R.
CORTEX_M4_0: Loader: One or more sections of your program falls into a memory region that is not writable. These regions will not actually be written to the target. Check your linker configuration and/or memory map.
CORTEX_M4_0: File Loader: Verification failed: Values at address 0x00000002 do not match Please verify target memory and memory map.
CORTEX_M4_0: GEL: File: C:\Users\Administrator\workspace_v9\WD_CJDY_2019\Debug\WD_CJDY_2019.out: a data verification error occurred, file load failed.
