我想要利用MSP432P401R(MASTER)寫一個可以透過spi發送命令並且接收slave回傳的數據的程式碼,我的想法是指令可以透過main迴圈裡面的SPI_transmitData(EUSCI_B0_BASE, TXData);發送,假設我有5個指令,那我可以在main透過連續5行此指令,只需更換TXData變數,然後發送給slave,並在中斷處,透過RXData = SPI_receiveData(EUSCI_B0_BASE);來接收從slave回傳的資料,但根據以下的程式碼,我的clock在示波器上顯示為'3.3V的一條直線,完全沒有嬰出現的波行,我不懂發生了什麼事?麻煩給予指教謝謝!
/* --COPYRIGHT--,BSD * Copyright (c) 2017, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * --/COPYRIGHT--*/ /****************************************************************************** * MSP432 SPI - 3-wire Master Incremented Data * * This example shows how SPI master talks to SPI slave using 3-wire mode. * Incrementing data is sent by the master starting at 0x01. Received data is * expected to be same as the previous transmission. eUSCI RX ISR is used to * handle communication with the CPU, normally in LPM0. Because all execution * after LPM0 is in ISRs, initialization waits for DCO to stabilize against * ACLK. * * Note that in this example, EUSCIB0 is used for the SPI port. If the user * wants to use EUSCIA for SPI operation, they are able to with the same APIs * with the EUSCI_AX parameters. * * ACLK = ~32.768kHz, MCLK = SMCLK = DCO 3MHz * * Use with SPI Slave Data Echo code example. * * MSP432P401 * ----------------- * | | * | | * | | * | P1.6|-> Data Out (UCB0SIMO) * | | * | P1.7|<- Data In (UCB0SOMI) * | | * | P1.5|-> Serial Clock Out (UCB0CLK) *******************************************************************************/ /* DriverLib Includes */ #include <ti/devices/msp432p4xx/driverlib/driverlib.h> /* Standard Includes */ #include <stdint.h> #include <stdbool.h> /* Statics */ static volatile uint8_t RXData = 0; static uint8_t TXData = 0; //![Simple SPI Config] /* SPI Master Configuration Parameter */ const eUSCI_SPI_MasterConfig spiMasterConfig = { EUSCI_B_SPI_CLOCKSOURCE_SMCLK, // SMCLK Clock Source 3000000, // SMCLK = DCO = 3MHZ 500000, // *** = 500khz EUSCI_B_SPI_MSB_FIRST, // MSB First EUSCI_B_SPI_PHASE_DATA_CHANGED_ONFIRST_CAPTURED_ON_NEXT, // Phase EUSCI_B_SPI_CLOCKPOLARITY_INACTIVITY_HIGH, // High polarity EUSCI_B_SPI_3PIN // 3Wire SPI Mode }; //![Simple SPI Config] int main(void) { /* Halting WDT */ WDT_A_holdTimer(); //![Simple SPI Example] /* Selecting P1.5 P1.6 and P1.7 in SPI mode */ GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P1, GPIO_PIN5 | GPIO_PIN6 | GPIO_PIN7, GPIO_PRIMARY_MODULE_FUNCTION); /* Configuring SPI in 3wire master mode */ SPI_initMaster(EUSCI_B0_BASE, &spiMasterConfig); /* Enable SPI module */ SPI_enableModule(EUSCI_B0_BASE); /* Enabling interrupts */ SPI_enableInterrupt(EUSCI_B0_BASE, EUSCI_B_SPI_RECEIVE_INTERRUPT); Interrupt_enableInterrupt(INT_EUSCIB0); Interrupt_enableSleepOnIsrExit(); //![Simple SPI Example] TXData = 0x01; /* Polling to see if the TX buffer is ready */ while (!(SPI_getInterruptStatus(EUSCI_B0_BASE,EUSCI_B_SPI_TRANSMIT_INTERRUPT))); /* Transmitting data to slave */ SPI_transmitData(EUSCI_B0_BASE, TXData); PCM_gotoLPM0(); __no_operation(); } //****************************************************************************** // //This is the EUSCI_B0 interrupt vector service routine. // //****************************************************************************** void EUSCIB0_IRQHandler(void) { uint32_t status = SPI_getEnabledInterruptStatus(EUSCI_B0_BASE); uint32_t jj; SPI_clearInterruptFlag(EUSCI_B0_BASE, status); if(status & EUSCI_B_SPI_RECEIVE_INTERRUPT) { /* USCI_B0 TX buffer ready? */ while (!(SPI_getInterruptStatus(EUSCI_B0_BASE, EUSCI_B_SPI_TRANSMIT_INTERRUPT))); RXData = SPI_receiveData(EUSCI_B0_BASE); /* Send the next data packet */ //SPI_transmitData(EUSCI_B0_BASE, ++TXData); /* Delay between transmissions for slave to process information */ //for(jj=50;jj<50;jj++); } }
