警报信息如下:
Description Resource Path Location Type
#10247-D creating output section ".cinit" without a SECTIONS specification tmIoT_boot C/C++ Problem
#10278-D LOAD placement specified for section ".text:decompress:none:rtsv7M4_T_le_v4SPD16_eabi.lib<copy_decompress_none.obj>". This section contains decompression routines required for linker generated copy tables and C/C++ auto-initialization. Must ensure that this section is copied to run address before the C/C++ boot code is executed or is placed with single allocation specifier (ex. "> MEMORY"). tmIoT_boot C/C++ Problem
#10278-D LOAD placement specified for section ".text:decompress:rle24:rtsv7M4_T_le_v4SPD16_eabi.lib<copy_decompress_rle.obj>". This section contains decompression routines required for linker generated copy tables and C/C++ auto-initialization. Must ensure that this section is copied to run address before the C/C++ boot code is executed or is placed with single allocation specifier (ex. "> MEMORY"). tmIoT_boot C/C++ Problem
#10278-D LOAD placement specified for section ".text:rtsv7M4_T_le_v4SPD16_eabi.lib<copy_decompress_rle.obj>". This section contains decompression routines required for linker generated copy tables and C/C++ auto-initialization. Must ensure that this section is copied to run address before the C/C++ boot code is executed or is placed with single allocation specifier (ex. "> MEMORY"). tmIoT_boot C/C++ Problem
#10278-D LOAD placement specified for section ".text:rtsv7M4_T_le_v4SPD16_eabi.lib<memcpy_t2.obj>". This section contains decompression routines required for linker generated copy tables and C/C++ auto-initialization. Must ensure that this section is copied to run address before the C/C++ boot code is executed or is placed with single allocation specifier (ex. "> MEMORY"). tmIoT_boot C/C++ Problem
#10278-D LOAD placement specified for section ".text:rtsv7M4_T_le_v4SPD16_eabi.lib<memset_t2.obj>". This section contains decompression routines required for linker generated copy tables and C/C++ auto-initialization. Must ensure that this section is copied to run address before the C/C++ boot code is executed or is placed with single allocation specifier (ex. "> MEMORY"). tmIoT_boot C/C++ Problem
