CC2642 IAR 编译问题
以下两个截图是iar编译cc2642 的project-zero工程相关报错,IAR版本是8.11.3
 下面这个截图是路径配置
在相同的路径配置下,cc2642的central工程编译正常
  • sdk_3_10_00_53 需要用IAR EWARM-8.32.2
  • SimpleLink CC13x2 / CC26x2 SDK 3.10.00.53 was built & tested on a Windows host platform using the following Integrated Development Environments (IDEs) and components. Using an IDE or toolchain version not listed below may result in compatibility issues with this SDK release. Refer to the individual component release notes in the Document Overview for each component’s supported code generation tools.
    IAR Embedded Workbench: EWARM-8.32.2
    TI Code Composer Studio: CCS-9.0.0.00013
