Error while running "C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\
..\..\..\..\..\..\..\xdctools_3_50_02_20_core\xs" --xdcpath="C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\
simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\kernel\tirtos\packages;C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source;C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack" iar.tools.configuro -c "D:\IAR8.32\arm" --cc "D:\
IAR8.32\arm\bin\iccarm.exe" --device "CC2640R2F" --compileOptions "dummy.c -D BOARD_DISPLAY_USE_LCD=0 -D
BOARD_DISPLAY_USE_UART=1 -D BOARD_DISPLAY_USE_UART_ANSI=1 -D CC2640R2_LAUNCHXL -D CC26XX -D CC26XX_R2 -D
DeviceFamily_CC26X0R2 -D xDisplay_DISABLE_ALL -D ICALL_EVENTS -D ICALL_JT -D ICALL_LITE -D ICALL_MAX_NUM_ENTITIES=6 -D
ICALL_MAX_NUM_TASKS=3 -D ICALL_STACK0_ADDR -D MAX_NUM_BLE_CONNS=1 -D POWER_SAVING -D RF_SINGLEMODE -D
STACK_LIBRARY -D TBM_ACTIVE_ITEMS_ONLY -D USE_ICALL -D xdc_runtime_Assert_DISABLE_ALL -D xdc_runtime_Log_DISABLE_ALL
--diag_suppress Pa050 -o C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\
app\FlashROM_StackLibrary\Obj --debug --endian=little --cpu=Cortex-M3 -f C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\config\build_components.opt -f C:\ti_140\
simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\
ble5stack\config\factory_config.opt -f C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\
simple_peripheral\tirtos\iar\app\..\stack\build_config.opt -f C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\
ble5stack\simple_peripheral\tirtos\iar\app\..\config\configPkg\compiler.opt.defs -e --fpu=None --dlib_config D:\IAR8.32\arm\inc\c\DLib_Config_Normal.h -I
C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\
ble5stack\controller\cc26xx_r2\inc\ -I C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\
tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\inc\ -I C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\
simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\common\cc26xx\ -I C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\src\app\ -I C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\icall\inc\ -I C:\ti_140\
ble5stack\inc\ -I C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\
..\..\..\..\source\ti\ble5stack\profiles\dev_info\ -I C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\
simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\profiles\roles\ -I C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\profiles\roles\cc26xx\ -I C:\ti_140\
ble5stack\profiles\simple_profile\ -I C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\
tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\profiles\simple_profile\cc26xx\ -I C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\target\ -I C:\ti_140\
ble5stack\hal\src\inc\ -I C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\
app\..\..\..\..\..\..\..\..\source\ti\ble5stack\hal\src\target\_common\ -I C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\
ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\hal\src\target\_common\cc26xx\ -I C:\ti_140\
ble5stack\hal\src\target\cc2650\rom\ -I C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\
simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\heapmgr\ -I C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\icall\src\inc\ -I C:\ti_140\
ble5stack\osal\src\inc\ -I C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\
app\..\..\..\..\..\..\..\..\source\ti\ble5stack\services\src\saddr\ -I C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\
ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\services\src\sdata\ -I C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\
examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\devices\cc26x0r2\ -I C:\ti_140\
simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ -Ohz"
--linkOptions "--no_out_extension -o C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\
tirtos\iar\app\FlashROM_StackLibrary\Exe\ble5_simple_peripheral_cc2640r2lp_app_FlashROM_StackLibrary.out --config_def CC2650=2 --config_def
FLASH_ROM_BUILD=2 --map C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\
iar\app\FlashROM_StackLibrary\List\ble5_simple_peripheral_cc2640r2lp_app_FlashROM_StackLibrary.map --config C:\ti_140\
ble5stack\common\cc26xx\iar\cc26xx_app_and_stack.icf --keep __vector_table -f C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\config\configPkg\linker.cmd -f C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\
examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\config\lib_linker.cmd C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\
examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\config\ble_r2.symbols C:\ti_140\
simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\devices\
cc26x0r2\driverlib\bin\iar\driverlib.lib C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\
tirtos\iar\app\..\..\..\..\..\..\..\..\kernel\tirtos\packages\ti\dpl\lib\dpl_cc26x0r2.arm3 C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\drivers\lib\drivers_cc26x0r2.arm3 C:\ti_140\
simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\drivers\rf\
lib\rf_singleMode_cc26x0r2.arm3 C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\
tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\display\lib\display.arm3 C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\
ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\grlib\lib\grlib.arm3 C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\mw\lcd\lib\lcd.arm3 --entry __iar_program_start --vfe --text_out
locale" --profile release --projFile "C:\ti_140\simplelink_cc2640r2_sdk_1_40_00_45\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\
tirtos\iar\app\cc2640r2lp_app.ewp" --cfgArgs NO_ROM=0
#CC2640经常出现这个错误,平时都是重装解决的问题,同一个SDK下的不太例程有些可以通过,有些不行,
SDK 1.40
IAR 8.32,2
