根据例程README.html的说明,设备都在近距离情况下,上位程序使用npi_cm_host.py(对齐crcinit长度、获取连接参数的时间)、主机使用host_test和CC2640R2_LAUNCHXL。
结果如附件log所示,每十几秒才有信号值返回。
这个simplelink_cc2640r2_sdk_4_40_00_10版本的connection_monitor例程是稳定的吗?我现在的效果是正常的吗?有方法可以优化到秒级返回信号吗?
Using Default Hardcoded Values: or enter 3 default(cm_port host_port peerAddress) arguments. See -h help. Host comport is: COM9 Connection Monitor comport is: COM13 Peer Address is: 0xCAa13049e4d2 Outgoing gap_device_init 0100fe2608143342cf14bc551731754fbba4c7f28c132d0af4b00307b04087f41823754afba400000000 ----------------------------------------------- OpCode: 0x067f StatusSUCCESS HCI_EXT_GAP_CMD_STATUS_EVENT ['04', 'ff', '06', '7f', '06', '00', '00', 'fe', '00', '04', 'ff', '2c', '00', '06', '00', '72', '24', '83', '0e', '6c', '54', 'ff', '00', '05', '33', '42', 'cf', '14', 'bc', '55', '17', '31', '75', '4f', 'bb', 'a4', 'c7', 'f2', '8c', '13', '2d', '0a', 'f4', 'b0', '03', '07', 'b0', '40', '87', 'f4', '18', '23', '75', '4a', 'fb', 'a4'] ----------------------------------------------- Outgoing gap_establishLinkReq 0109fe09000001d2e44930a1ca ----------------------------------------------- OpCode: 0x067f Status15 HCI_EXT_GAP_CMD_STATUS_EVENT ['04', 'ff', '06', '7f', '06', '15', '09', 'fe', '00'] ----------------------------------------------- Outgoing hci_getCmConnInfo 0124fc0100 ----------------------------------------------- OpCode: 0x0424 StatusSUCCESS HCI_EXT_GET_ACTIVE_CONNECTION_INFO_EVENT Access Address: 0x99b9551c Connection Interval: 24 Hop Value: 0x10 Master Clock Accuracy: 0x0000 next Channel: 0x10 Channel Map: 0x1fffffffff CrcInit: 0x5f3f07 ['04', 'ff', '17', '24', '04', '00', '24', 'fc', '1c', '55', 'b9', '99', '18', '00', '10', '00', '00', '10', 'ff', 'ff', 'ff', 'ff', '1f', '07', '3f', '5f'] ----------------------------------------------- Outgoing cmStart() cmd fe1300570199b9551c0018100000101fffffffff5f3f07ffb3 Raw CM output: ['fe', '01', '00', '57', '01', '00', '57'] Master 1 RSSI -67 time: 6.49495425 seconds Slave 1 RSSI -83 time: 6.49518425 seconds Master 1 RSSI -70 time: 21.63249925 seconds Slave 1 RSSI -89 time: 21.6327295 seconds Master 1 RSSI -70 time: 36.6201835 seconds Slave 1 RSSI -88 time: 36.620414 seconds Master 1 RSSI -67 time: 51.5927865 seconds Slave 1 RSSI -83 time: 51.5930165 seconds Master 1 RSSI -66 time: 66.55026775 seconds Slave 1 RSSI -83 time: 66.55049825 seconds Master 1 RSSI -70 time: 81.52248075 seconds Slave 1 RSSI -90 time: 81.52271125 seconds Master 1 RSSI -67 time: 96.49500325 seconds Slave 1 RSSI -85 time: 96.49523375 seconds Master 1 RSSI -73 time: 111.467943 seconds Slave 1 RSSI -85 time: 111.468173 seconds Master 1 RSSI -74 time: 126.48598475 seconds Master 1 RSSI -70 time: 141.4436615 seconds Slave 1 RSSI -81 time: 141.4583565 seconds Master 1 RSSI -64 time: 156.415982 seconds Master 1 RSSI -67 time: 171.358136 seconds Slave 1 RSSI -78 time: 171.35836675 seconds Master 1 RSSI -67 time: 186.2855 seconds Master 1 RSSI -70 time: 201.213101 seconds Slave 1 RSSI -78 time: 201.22779825 seconds Master 1 RSSI -67 time: 216.1850025 seconds Slave 1 RSSI -77 time: 216.18523325 seconds Master 1 RSSI -67 time: 231.127153 seconds Slave 1 RSSI -81 time: 231.12738375 seconds Master 1 RSSI -70 time: 246.06957125 seconds Slave 1 RSSI -79 time: 246.084258 seconds Master 1 RSSI -67 time: 261.102053 seconds Slave 1 RSSI -81 time: 261.102283 seconds Master 1 RSSI -70 time: 276.0444745 seconds Slave 1 RSSI -79 time: 276.059165 seconds Master 1 RSSI -67 time: 290.9719685 seconds Master 1 RSSI -70 time: 305.884734 seconds Master 1 RSSI -70 time: 320.7972185 seconds Slave 1 RSSI -86 time: 320.797449 seconds Master 1 RSSI -70 time: 335.72489625 seconds Slave 1 RSSI -77 time: 335.7395895 seconds Master 1 RSSI -70 time: 350.66697725 seconds Slave 1 RSSI -86 time: 350.667208 seconds Master 1 RSSI -67 time: 365.6092645 seconds Slave 1 RSSI -84 time: 365.6239615 seconds Master 1 RSSI -67 time: 380.5664445 seconds Slave 1 RSSI -76 time: 380.56667475 seconds Master 1 RSSI -71 time: 395.52383625 seconds Slave 1 RSSI -87 time: 395.5240665 seconds Master 1 RSSI -70 time: 410.48104125 seconds Slave 1 RSSI -84 time: 410.481272 seconds Master 1 RSSI -67 time: 425.423762 seconds Master 1 RSSI -71 time: 440.38123225 seconds Slave 1 RSSI -88 time: 440.38146225 seconds Master 1 RSSI -70 time: 455.36878375 seconds Slave 1 RSSI -88 time: 455.369014 seconds Master 1 RSSI -70 time: 470.3264985 seconds Slave 1 RSSI -79 time: 470.34118825 seconds Master 1 RSSI -68 time: 485.29891575 seconds Slave 1 RSSI -85 time: 485.3136085 seconds Master 1 RSSI -70 time: 500.2407705 seconds Slave 1 RSSI -81 time: 500.24100075 seconds Master 1 RSSI -71 time: 515.21301025 seconds Slave 1 RSSI -88 time: 515.213241 seconds Master 1 RSSI -70 time: 530.17026475 seconds Slave 1 RSSI -85 time: 530.17049525 seconds Master 1 RSSI -68 time: 545.1279445 seconds Slave 1 RSSI -77 time: 545.14264075 seconds Master 1 RSSI -70 time: 560.115751 seconds Slave 1 RSSI -82 time: 560.11598125 seconds Master 1 RSSI -67 time: 575.0891645 seconds Master 1 RSSI -71 time: 590.04637475 seconds Slave 1 RSSI -88 time: 590.04660475 seconds Master 1 RSSI -70 time: 605.00371625 seconds
