CC1101 : the relationship about frequency deviation , data rate and Filter bandwidth .
Other Parts Discussed in Thread: CC1101
    How do i compute the frequency deviation and filter bandwidth through the data rate.
    this is my register parameter : data rate ---- 1.2kBaud ;   Base Frequency ---- 433MHz ; Xtal Frequency ---- 26MHz ; Accuracy of crystals ---- 10ppm
Now , I use CC1101 for broadcast communications, but only on one side.
So , can you help me !!!!!!!!!!!!!!!!
