【最热MSP430相关的NFC整体参考设计】
Connectivity TIDM-NFC-I2C-MODULE : NFC I2C Reader Module Reference Design (http://www.ti.com/lit/an/sloa199/sloa199.pdf G2553 Low Cost, Small Form Factor
Connectivity TIDA-00230 : NFC Configuration & Logging Interface ( Dual Port FRAM: NFC-FRAM-Serial) (http://www.ti.com/lit/ug/tidu388/tidu388.pdf FR5969 8Mbps Throughput via FRAM over Serial, 800Kbps Throughput over NFC via FRAM
Connectivity TIDM-RF-Sensornode : Development Platform for 6LowPAN (http://www.ti.com/lit/ug/tidu240/tidu240.pdf ) F5438A  Multiple interface/COM ports ( upto 8),  Software with Contiki OS
Connectivity TIDA-00217 : Dynamic Field-Powered NFC for Data Logging Access Control & Security Applications Reference Design (http://www.ti.com/lit/ug/tidu378a/tidu378a.pdf ) FR5969 FRAM for fast data write, AES256 security, Ultra low Power
Connectivity TIDM-DYNAMICNFCTAG : Dynamic Near Field Communication (NFC) Type 4B Tag (http://www.ti.com/lit/ug/slou373a/slou373a.pdf FR5738 FRAM, Small Form Factor
Connectivity TIDM-BATTERYLESSNFCKEYBOARD : Battery-less Near Field Communication (NFC) Keyboard (http://www.ti.com/lit/ug/tidu398/tidu398.pdf FR5739 FRAM, Small Form Factor
Connectivity TIDM-NFC-EZ430-MODULE : NFC EZ430 Reader Module Reference Design (http://www.ti.com/lit/an/sloa199/sloa199.pdf
