[10:35:00] Begin Format operation.
[10:35:00] INFO: > Executing Operation: Connect
[10:35:02] INFO: setting break signal
[10:35:03] INFO: detecting FTDI for device reset
[10:35:19] ERROR: ---reading ACK signal failed---
[10:35:19] WARNING: ---seting break signal to false failed---
[10:35:21] INFO: setting break signal
[10:35:22] INFO: detecting FTDI for device reset
[10:35:37] ERROR: ---reading ACK signal failed---
[10:35:38] WARNING: ---seting break signal to false failed---
[10:35:40] INFO: setting break signal
[10:35:41] INFO: detecting FTDI for device reset
[10:35:56] ERROR: ---reading ACK signal failed---
[10:35:56] WARNING: ---seting break signal to false failed---
[10:35:58] INFO: setting break signal
[10:35:59] INFO: detecting FTDI for device reset
[10:36:15] ERROR: ---reading ACK signal failed---
[10:36:15] WARNING: ---seting break signal to false failed---
[10:36:15] FATAL: --- Can't connect to device !! ---
[10:36:15] FATAL: Error connecting to the device. Please check your COM port settings. Error code: -3
[10:36:15] INFO: > Executing Operation: Disconnect
[10:36:15] Operation Format returned.
