ccs6 导入项目报错,显示安装 MSP432v15.12 compiler
我使用的CCS V6,在导入项目的时候,报错,提示:See details below.
  Error: Import failed for project 'iot_sdk' because its compiler definition is not available. Please install the MSP432v15.12 compiler before importing this project - click 'View > CCS App Center' to check if compiler updates are available, or install the compiler manually and register it with CCS through 'Preferences > CCS > Build > Compilers'.
想知道MSP432v15.12 compiler在哪下载安装,CCS App Center没有MSP432v15.12 compiler
2 个回复
