C:\ti\CC3200SDK_1.4.0\cc3200-sdk\example\get_time
错误如下:
Error[Li060]: module "xdc_init.orm4(iar.targets.arm.rts.arm4)" contains C++ code built for use with the (E)C++98 library. This code is not link compatible with the new (C++14) library.
Fatal Error[Li001]: could not open file "C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0\arm\lib\dlpp7M_tl_ne.a"
