用UNI FLASH 5.0 给 cc3200 LANGCHXL 开发板刷程序报错
错误如下:
 [ERROR] Cortex_M4_0: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
11 个回复
