ti_rtos_config 工程导入CCS报错,如何解决
See details below.
Error: Import failed for project 'ti_rtos_config' because its compiler definition is not available. Please install the ARMv18.1 compiler before importing this project - click 'View > CCS App Center' to check if compiler updates are available, or install the compiler manually and register it with CCS through 'Preferences > CCS > Build > Compilers'.
  • 根据您的错误提示,应该是您的编译器问题。请您确定是否有安装编译器以及对应的版本
    按照给出的解决方法来试一下
