[19:33:43] Begin Program operation.
[19:33:45] INFO: Checked for update config groups: []
[19:33:45] INFO: List of files to be generated: []
[19:33:45] INFO: > Executing Operation: Connect
[19:33:47] INFO: setting break signal
[19:33:47] INFO: --- please restart the device ---
[19:34:02] ERROR: ---reading ACK signal failed---
[19:34:02] WARNING: ---seting break signal to false failed---
[19:34:04] INFO: setting break signal
[19:34:04] INFO: --- please restart the device ---
[19:34:19] ERROR: ---reading ACK signal failed---
[19:34:19] WARNING: ---seting break signal to false failed---
[19:34:21] INFO: setting break signal
[19:34:21] INFO: --- please restart the device ---
[19:34:36] ERROR: ---reading ACK signal failed---
[19:34:36] WARNING: ---seting break signal to false failed---
[19:34:38] INFO: setting break signal
[19:34:38] INFO: --- please restart the device ---
[19:34:53] ERROR: ---reading ACK signal failed---
[19:34:53] WARNING: ---seting break signal to false failed---
[19:34:53] FATAL: --- Can't connect to device !! ---
[19:34:55] FATAL: Error connecting to the device. Please check your COM port settings. Error code: -3
[19:34:55] INFO: > Executing Operation: Disconnect
[19:34:55] Operation Program returned.
[19:36:22] Begin Format operation.
[19:36:23] INFO: > Executing Operation: Connect
[19:36:25] INFO: setting break signal
[19:36:25] INFO: --- please restart the device ---
[19:36:40] ERROR: ---reading ACK signal failed---
[19:36:40] WARNING: ---seting break signal to false failed---
[19:36:42] INFO: setting break signal
[19:36:42] INFO: --- please restart the device ---
[19:36:57] ERROR: ---reading ACK signal failed---
[19:36:57] WARNING: ---seting break signal to false failed---
[19:36:59] INFO: setting break signal
[19:36:59] INFO: --- please restart the device ---
[19:37:14] ERROR: ---reading ACK signal failed---
[19:37:14] WARNING: ---seting break signal to false failed---
[19:37:16] INFO: setting break signal
[19:37:16] INFO: --- please restart the device ---
[19:37:31] ERROR: ---reading ACK signal failed---
[19:37:31] WARNING: ---seting break signal to false failed---
[19:37:31] FATAL: --- Can't connect to device !! ---
[19:37:31] FATAL: Error connecting to the device. Please check your COM port settings. Error code: -3
[19:37:31] INFO: > Executing Operation: Disconnect
[19:37:31] Operation Format returned.
