HI YK
這幾天試了一下Z-Stack Linux Gateway
再去爬了一下文. 發現你有提到只在Debian 7.8版本( IN BeagleBone Black ) 正常
我現在試了Debian 10.3版( IN BeagleBone Black )執行:
(BeagleBoard.org Debian Buster IoT Image 2020-04-06)
"sudo ./zigbeeHAgw beaglebone"
也是一樣一堆錯( BeagleBone Black 有上網)
"connect: Connection refused
[ZSTACKZNP_SRVR/MAIN] ERROR: ERROR: signal 11 was trigerred:
[ZSTACKZNP_SRVR/MAIN] ERROR: Fault address: (nil)
[ZSTACKZNP_SRVR/MAIN] ERROR: Fault reason: address not mapped to object
[ZSTACKZNP_SRVR/MAIN] ERROR: Stack trace unavailable
[ZSTACKZNP_SRVR/MAIN] ERROR: Executing original handler...
./zigbeeHAgw: line 351: 29620 Segmentation fault $ZLSZNP_CMD
ZLSZNP started (pid 29620) at Mon 07 Sep 2020 02:05:37 PM UTC
[NWK_MGR/MAIN] : there are 2 args
[NWK_MGR/MAIN] : argv[0] = ./NWKMGR_SRVR_arm
[NWK_MGR/MAIN] : argv[1] = 127.0.0.1:2536
[NWK_MGR/MAIN] ERROR: ERROR: signal 11 was trigerred:
[NWK_MGR/MAIN] ERROR: Fault address: (nil)
[NWK_MGR/MAIN] ERROR: Fault reason: address not mapped to object
[NWK_MGR/MAIN] ERROR: Stack trace unavailable
[NWK_MGR/MAIN] ERROR: Executing original handler...
./zigbeeHAgw: line 407: 29623 Segmentation fault $NWKMGR_CMD $NWKMGR_RESTART_FLAG
NETWORK MANAGER started (pid 29623) at Mon 07 Sep 2020 02:05:38 PM UTC
[GATEWAY/MAIN] ERROR: ERROR: signal 11 was trigerred:
[GATEWAY/MAIN] ERROR: Fault address: (nil)
[GATEWAY/MAIN] ERROR: Fault reason: address not mapped to object
[GATEWAY/MAIN] ERROR: Stack trace unavailable
[GATEWAY/MAIN] ERROR: Executing original handler...
./zigbeeHAgw: line 378: 29626 Segmentation fault $GATEWAY_SERVER_CMD
GATEWAY SERVER started (pid 29626) at Mon 07 Sep 2020 02:05:40 PM UTC
[OTASRVR/MAIN] ERROR: ERROR: signal 11 was trigerred:
[OTASRVR/MAIN] ERROR: Fault address: (nil)
[OTASRVR/MAIN] ERROR: Fault reason: address not mapped to object
[OTASRVR/MAIN] ERROR: Stack trace unavailable
[OTASRVR/MAIN] ERROR: Executing original handler...
./zigbeeHAgw: line 438: 29629 Segmentation fault $OTA_SERVER_CMD
OTA SERVER started (pid 29629) at Mon 07 Sep 2020 02:05:42 PM UTC
starting tracker with our pid ./zigbeeHAgw and pid list 29615 29620 29626 29629
只能用Debian 7.8版本或是官網的am335x-evm-linux-06.03.00.106.img
( IN BeagleBone Black )了嗎??
謝謝.
