zigbee新手,用的2530和2.5.1a的协议栈。
在f8wconfig.cfg里面修改了pan id,可是只有协调器的pan id改了,路由的依旧是FFFF,抓包一直显示beacon request,就是组不了网,这是为什么路由无法加入协调器.psd
NLME_PermitJoiningRequest()
This function defines how the next higher layer of a coordinator or router device may permit devices to join its network for a fixed period.
Prototype
ZStatus_t NLME_PermitJoiningRequest( byte PermitDuration );
Parameter Details
PermitDuration - The length of time during which the a device (coordinator or router) will be allowing associations. The values 0x00 and 0xff indicate that permission disabled or enabled, respectively without a time limit. Values 0x01 – 0xFE are the number of seconds to allow joining.
Return
ZStatus_t –status values defined in ZComDef.h.
可以調用API ZDP_MgmtPermitJoinReq使能permitjoin
